Question about Techko S184 Vibration Activated Security Door Alarm and Door Chime
Alarm goes off before any vibration has occurred....
Hung on door knob, turned on, 10 seconds later the alarm/chime (whichever it's set for) goes off on its own without touching. What do we do?
Send to: wegotrhythm@yahoo.com
Thanking you in advance,
Lisa and Steve
It may be the device. I bought two of them at the same time. One has worked fine but the other went off for no apparent reason at 5:00 AM. It does wake you up out of a deep sleep. After reading some about it I figured the airconditioner was moving some clothing on the door and the movement set it off or the device was just not a good one. I quit using it but continue to use the other and it works fine. Just your air conditioning vent or things you might have hanging on the door.
Hope this helps,
Betty
Posted on Jun 21, 2008
How to turn off the alarm?
http://www.freestyleusa.com/support/
the second window down has the buzz instructions.
in the buzz instructions
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
May 30, 2014 | Freestyle Shark Buzz Wrist Watch
Interior lights on 95 grand am done went slap stupid.
Power Output Diagnostic Mode
You may use a power output diagnostic mode in the multifunction alarm module in order to run a quick test on the operation of the following outputs:
• The courtesy lamps control
• The inadvertent power control
The power output diagnostic mode activates after you perform all of following actions:
• Close all of the doors.
• Set the park brake.
• Turn the ignition switch to RUN.
Before 15 seconds pass, perform the following steps:
• Open the right front door.
• Cycle the headlamp switch from OFF to PARK three times.
During a normal operation, the multifunction alarm module will flash the interior lamps until the ignition switch turns OFF. If an internal short occurs in the multifunction alarm module, the module will chime in the following patterns:
• One chime every 3 seconds implies an inadvertent output failure.
• Two chimes every 3 seconds implies a courtesy output failure.
Sep 14, 2017 | Cars & Trucks
Location of tail gate alarm on 2004 Chrysler Pacifica
you may have a bad switch which is located on the latch asm
Sep 03, 2012 | 2004 Chrysler Pacifica
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
Interior lights stay and alarm goes off every time i lock it
Your car thinks a door is open , thus the light stays on. When you lock the doors with the remote it activates the alarm system. 10 sec later it senses that the a door is open and alarm sounds.
I have a 99 passat as well and I just went outside to see where the switch on the door is. Can't see one anywhere , it must be inside the door (part of the latch mechanism). I tried to arm the alarm system by locking the doors with the remote while the door was still open , sure enough the alarm went off about 15 secs later.
Nov 05, 2009 | 1999 Volkswagen Passat
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
2) Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Remove key from ignition
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Aug 12, 2008 | GE Security Simon 3 Wireless Home Security...
Techko S184 Vibration Activated Security Door Alarm and Door Chime Logo
217 people viewed this question
Top Techko Home Security Experts
Lawrence Oravetz
Are you a Techko Home Security Expert? Answer questions, earn points and help others
