Question about Xerox 8830 Copier
Xerox 8830 ERROR CODE LL56 - Xerox 8830 Copier
  • 3,530 Answers
This is an issue with the power board.
Power the Printer OFF / ON
NOTE: Make sure you power OFF the printer before powering OFF the Controller, and power ON the printer before you power ON the Controller.
1. Power OFF the printer. The power switch is located directly to the left of where the power cable enters the machine.
2. If you have a Controller installed, power OFF the Controller. Not all printers are equipped with a Controller. The Controller power switch is located just above the power switch.
3. Wait at least 10 seconds.
NOTE: Powering OFF, and then ON again too quickly will result in a software error.
4. Power ON the printer.
5. Power ON the Controller.
6. Switch the A / B button to the ON position. The button will be in the out position and the green light will be ON.
Please let me know if this works
Thank you!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Nov 08, 2010
LL56
This type of code has not recovery procedure which could mean replacement of hardware component. LL-56 refers to a power board fault on the printer and occurs during power on self test.
Refer page 1-10 for the code description in this service manual.
http://www.printertec.com.br/arquivos_download/xerox/xerox8825.pdf
Jul 31, 2014 | Xerox 8830 Copier
How do you reset an Error code LL-05 on a Xerox 8830
enter in diagonistic mode by pressing 0 then on then press10-30 then on andoff
Oct 19, 2010 | Xerox 8830 Copier
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL43 error
An LL43 is a fuser temperature error.
When you first turn on the printer it should display printer warming up and after a little while display the LL43. If the fuser is still cold then you probably blew the thermal fuse and it will need to be replaced.
Oct 01, 2009 | Xerox 8830 Copier
Error code E701
Е-701 the malfunction on frequency temporary signal, which can arise out of for undue execution temporary parameter. The Sensors fix time of the passing the paper in feeder, it not always coincides. You it is necessary to apply to service service and do service. This not big worries. Good luck!
Sep 13, 2009 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Jun 15, 2009 | Xerox 8830 Copier
E4-14
pls check stripper finger assembly
Mar 16, 2009 | Xerox 8830 Copier
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
