Question about Magimix 5150 Food Processor
Brand new magimix food processor 4200 will not work, blade either just turns or won't turn at all, checked all fittings, tried different power terminals
4 Suggested Answers
SOURCE: I've just purchased a Magimix 4200XL and only have
I solved the problem by contacting the retailer i bought it from who promptly gave me the 'missing' blade from one of his other 4200XL units. He said it must have been accidentally packed at the manufacturers without it.
Happy Customer now :)
Posted on Aug 01, 2009
co7196
  • 3433 Answers
SOURCE: need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Posted on Oct 31, 2009
elaine482
  • 3 Answers
SOURCE: is it possible to get
Sure is! You can download one from here: http://www.foodprocessorreview.co.uk
Posted on Oct 15, 2011
How can I test the motor relay on a Magimix food processor?
Overloading may have caused a thermal protector buried in the motor windings to open in which case the motor will have to be replaced.
Jun 04, 2016 | Magimix 4100 Cuisine Systeme 1268 Cups...
How do I change the Nylon Driveshaft on my Magimix 4200?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and support the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 26, 2014 | Magimix C.s.4200 xl chrome mat - Mixeur...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
The metal blade does not reach the bottom of the bowl
I am confused by this too! I have a brand new magimix 5200 and all my blades sit about 2 centimetres above the bottom of the bowl resulting in nothing being mixed below them. Very annoyed after spending $700 on this thing!!!
Dec 06, 2013 | Magimix 5150 Food Processor
The Magimix makes a terrible (loud and harsh but short) clicking sound when turned on, either regular or pulse. It sounds ok when running and performs its functions as usual. This is happening ever since I...
you might have damaged the gear-train, Depending on what you payed for this unit it might be best to put up with it for as long as you can and purchase a new one when it brakes down
cost of repairs can easly equal or exeed the cost of a new unit with warenty
Best regards Falco
Nov 04, 2013 | Magimix 18527 5200 Food Processor, Chrome
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
I am missing blades and slicers for a 3000 series.Do you stock these
cannot release bowl, tried turning to release won`t turn!
Sep 30, 2009 | Magimix Food Processors
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix 5150 Food Processor Logo
52 people viewed this question
Top Magimix Food Processors Experts
richie46
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
