Question about HP W2007 LCD Monitor
The color is "off" on
  • 732 Answers
Ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Posted on Nov 08, 2010
My monitor suddenly has a pink hue to it. HOw do you fix that?
hit the menu button and play around with your color options. It is likely that these somehow got adjusted.
Aug 26, 2011 | X2Gen Computers & Internet
The color / hue on my sony monitor seems to be pink how do I adjust it to its normal color ?
Click on the link below and download the manual to know how to change settings of your monitor
Monitor Settings Manual
Regards,
Shawn
Feb 03, 2011 | Sony SDM-HS95 19" LCD Monitor
HP w2007, monitor display goes slightly pink in color, gets dark. Caps?
That can be bad lamps, or bad caps also, but I suspect the lamps.
When lamp gets old it usualy turn on pink and turn white after warm up, but if it is really bad, it will cause the inverter circuits to go into shut down to protect the circuits since bad lamp can draw excessive current. You can see bad lamp album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | HP W2007 LCD Monitor
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then...
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
May 08, 2009 | AOpen F2715-8S Monitor
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Apr 12, 2009 | Mag Innovision Computers & Internet
I just purchased an HP w2007 hp monitor. After going through all the suggested start up routines, images are stretched horizontally. I'm using XP home edition with sp 3. My resolution doesn't seem to go...
if it's a wide screen monitor then the monitor is likely doing the stretching and you have to adjust using the monitor controls (either buttons on the monitor itself or it may have come with software as well if you loaded a CD when you first installed).
Mar 31, 2009 | HP W2007 LCD Monitor
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
HP W2007 LCD Monitor Logo
192 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
