Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
What are the causes of hissing sound in a JBL EON Power 15 Powered Speaker 800 Watts
5 Suggested Answers
  • 4234 Answers
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Posted on Aug 14, 2008
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Posted on Sep 21, 2008
freetek
  • 5568 Answers
SOURCE: Speaker was dropped - Tweeter Magnet came off -
Clean the mating surfaces very well, mark on the side of the magnet (arrow or dot) which surface of the magnet was glued (shouldn't make a bit of difference, I'm just a little anal) and then use any brand of quick setting 'super glue.' This glue will not only hold well but will also introduce the thinnest film between the magnet and 'keeper.' Too much space between mating surfaces can weaken the field and reduce the efficiency causing an imbalance in volume relative to the other tweeter. If anything else is loose, the tweeter is junk because any shift of the voice coil will cause the speaker to distort or rattle.
If you need to replace any speaker ever, replace both channels or have possibly lousy matching between channels.
Posted on Apr 24, 2009
  • 104 Answers
SOURCE: Damaged JBL Eon15 Tweeter
you can probably by a generic type of motherboard from a shop like JAYCAR lookem up on the net ]
Posted on May 26, 2009
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How much for speaker
JBL EON 15-G2 Powered Sale Price: $649.95
Jan 04, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Hiss from the tweeter nothing from the sub
Trash. Don't run your bass through speakers not designed for it. Likewise (from personal experience) don't allow microphone feedback to get into consumer speakers. Bye-bye tweeters in either case.
Nov 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
261 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
