Question about Epson Stylus Photo R1800 InkJet Printer
How can I clean the print heads on an Epson R1800? Or do I need to take it in to have it done. Who in Phoenix does this?
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
My yellow ink head on my r1800 printer is clogged.
If it is within warranty then contact epson support. If not and normal head cleaning doesnt work then try a print head cleaning solution such as:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Hope this helps.
Mar 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printhead protector
Hi-
Nope you dont need one. Just turn the printer off while not in use or if youre planning not to use it for a long time, run some head cleaning cycles as well and print a nozzle check before printing photos. have the same printer and love them so much.
Thanks for using fixya!
Sep 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
RED WON'T PRINT
Hi-
Try running a head cleaning from your computer, if you are using XP go to printers and faxes under control panel and right click on your printer icon then go to printing preferences then go to maintenance and run head cleaning cycles for 3x then print a nozzle again. if all fails cal epson and check for the warranty so that you can have it replace, coz chances are the nozzle for magenta is clog.
Hope this helps
Sep 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
R1800 printing way too green/yellow
I have the same problem. Your printer head is clogged. You can use the head cleaning utility within Epson. However, if that doesn't work, you may need to use a head cleaning solution.
Apr 27, 2008 | Epson Stylus Photo R1800 InkJet Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
