Question about Hitachi 43FDX01B TV
Hitachi 43FDXo1B red will not line onconvergence it is off to the right about inch. screen shakes
  • bigchz Jun 20, 2008
    I have replaced convergance chips (both) I have also replaced RK42, RK46, RK50, RK54, RK58, RK62. I still have a small issue with the red, but a really bad issue with the blue. When I use the convergance button it allows me to adjust the center lines but the lines that need adjusting are on the left. Both red and blue. When I try to adjust the blue it blinks once and back to wher I started not allowing me to adjust the blue. I boogered up the chip sets when I took them out, which made it hard to create good connections on the wires. It is still having the same issue as before though. I can't understand it. Can anyone help me?
Do you charge
Posted on Dec 28, 2010
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Posted on Jun 19, 2008
I have a hitachi 43fdxo1b and sreen has a blue tinit on everything
Go to the front where the speakers are and pull off panel, there will be a panel with some screws on it, Take it off, you will see your focus block. Top is g2 (screen) they will be marked bgr. B is on the top left, turn it counter clockwise.
Sep 11, 2011 | Hitachi 43FDX01B TV
I have a 65 inch Hitachi HDTV. There are red,
Sounds like you need to purchase a convergence kit. Instuctions are included
Jul 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Red vertical line appears intermittently
you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
Jan 23, 2009 | Hitachi 55HDX61 Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
Thin red line on Hitachi plasma
If it goes all the way from top to bottom, you have a bad panel. much to expensive to repair
Aug 10, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
My tv is hitachi 55pd plasma
have a tech check your tv the vertical module needs to be replaced.good luck
Apr 18, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi 43FDX01B TV Logo
175 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
