Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hi, I have a Hitachi 46F500 Rear Projection TV with a Out of Sync color problem. The red doesn't align with the blue or green. The repair cost is $300+ with a repairman, but the parts are around $30, and I need a project anyways. This is the second time this has happened. Fiddling with MagicFocus helped, but not much. I've searched through several similar posts, all have a response from an expert stating they had reference materials and a how-to guide on how to repair it, but none actually had the resources posted. I'm looking for those documents please. I don't currently own an Ohmmeter, but I will buy one when I buy the required replacement parts (To my knowledge, two chips, a few resistors, and a fuse or two - but I'm not sure exactly which type of each I need) I'm fairly knowledgeable with software, but I only have a very basic knowledge with hardware. Any solution that helps will get a 100% rating, and a HUGE thank you!
  • Acron Nov 08, 2010
    I would also like to note that I tried leaving it unplugged for over a half hour to see if it would be able to reset.
  • Hitachi Master
  • 8,457 Answers
Tools u must have to do the job.A soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,can u also do basic soldering?Yes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete convergence kit for ur tv model and make to repair it ur self.This convergence kit will also come with a DVD disc of instructions.The price is not $30,like $65 plus shipping.
Posted on Nov 08, 2010
Testimonial: "Thanks a lot! TVrepairkits had exactly what I needed!"
My red green and blue colors are not aligned
thats a convergence issue you can get the convergence repair kit which contains the parts and instructions from the www.tvrepairworld.com just click on the Hitachi Repair kits catagory then scroll down the page to your models convergence kit.
Jan 02, 2013 | Hitachi 46F500 46" Rear Projection...
On the right side of the screen it is turning red and is not aligning properly looks like it is trying to go 3d. what could cause this?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Hitachi 46F500 46" Rear Projection...
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
Colors look like 3-D
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 05, 2010 | Hitachi 46F500 46" Rear Projection...
I have a hitachi model 46f500 that looks distorted. (3d)
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Mar 20, 2010 | Hitachi 46F500 46" Rear Projection...
Green convergence is not converging properly
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Hitachi 46F500 46" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color problem
that would tell me somethings no right with your tuner, that its not outputting choma.
Jan 12, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi big screen tv
Convergence IC's bad==replace and then
re-check alignment
Oct 16, 2007 | Hitachi 46F500 46" Rear Projection...
Convergence on Hitachi 46f500
replace convergence IC's,then re-check alignment
Sep 17, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
485 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
