Fires up then shuts off. Looking for flame sensor model number.
  • 1 more comment
  • roger_b566 Nov 08, 2010
    Thanks, I have been searching for a Rheem rep in my area.
  • roger_b566 Nov 09, 2010
    The model number for the Rheem Conquest 80 is GMUH100-E3N
    Thanks problem solved.
  • 2,069 Answers
Just indicate your units brand and model then we will get you the flame sensor part number and possibly where to get it.
Posted on Nov 08, 2010
  • Muzahura Frank Nov 09, 2010
    you could first of all go here. rheem flame sensors are listed there and very good installation instructions accompany the service.
Pentair minimax nt heater
its not sensing flame you have to look at the burners make sure all of them light. Many times spiders wil get into the gas jets, you can use a number 12 solid copper wire to insert it into the gas jet you will see it ,the flame sensor burner is not having a good flame
Apr 12, 2014 | Pentair Minimax NT Heater
Hvac turns on and shuts off after 3 tries
just to be sure this is a gas fired furnace? - what make and model?
behind most not all are sensors behind or near the blower fan - these little buggers are easily missed if you have one - jumper the wires and see if it fires if it does this sensor need replacing -
Mar 20, 2014 | Coleman York Dgat Gas Furnace Flame Sensor...
Heater fires and shuts off repeatedly. reads CHF. Has good flow.
error code should be inside heater make shure you have adequate gas pressure also sounds like bad flame sensor when flame sensor doesnt sense flame it will shut off after 7 seconds
Oct 02, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Torpedo Reedy heater 150,000 BTU starts & fires but after 2-3 minutes of heating , it shuts down, after it is off for about 3 minutes it will start & fires but then shuts down , each time it shuts...
There is a flame sensor inside the burner unit. The sensor is like a photo cell that must see the light of the flame or it will tell the burner control to stop the power. You need to see if there is a soot film on the lense of the sensor and make sure the sensor is aimed straight. If the sensor is clean and aimed straight (and the problem persists) then there may be a clogged nozzle that is giving a poor flame and the sensor does not see a good flame therefore shuts down the unit. If the nozzle is at fault, then you for sure need to replace the oil filter. New nozzles are $4-8 and the size & spray angle is stamped on the nozzle. If there is still a problem, then you need to see if the pump is giving approx. 100psi pressure, then finally (the last step) would be to replace the burner control $60. Goodluck< Macgivor
Jan 16, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
GOODMAN GAS FURNACE. IGNITOR GLOWS, GAS FIRES FOR 3-4 SECONDS THEN SHUTS OFF..CYCLES OVER AND OVER. SOMETIMES IT STAYS ON...THEN SHUTS OFF BEFORE TEMPERATURE GETS UP TO THE STAT SETTING...
I suspect that the flame is not traveling to all the burners within a given time so the flame sensor is shuting down the gas valve. Clean out the flame rail where the flame travels and carefully brush off the flame rod with an old tooth brush.
Oct 19, 2009 | Goodman GMS90703BXA Heater
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
My oven will not light and there does not seem to be any gas going to the burner.
its probably your thermocouple an older one you'll see the pilot light/on newer models after it fires theres a flame sensor eye to distinguish that theres a flame and to continue to supply gas,if no flame is detected the gas valve is shut off for safety,the flame sensor eye could be defective or dirty also
Jun 26, 2009 | Frigidaire Ovens
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
