Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
I have a NetGear WPN824v3 Wireless Router. I have two issues. First and most important is that it will NOT allow me to forward port 53 (DNS). It keeps saying that I need to check other areas of the configuration - some of which do not even INVOLVE ports! The SECOND issue is that I found a firmware upgrade, but the router says it is not a valid file. (WPN824V3-V1.0.8_1.0.7NA.img) Any thought? (FYI, I am a computer tech...)
  • timelord1957 Nov 14, 2010
    I found the solutions! The solution to the FIRST (unable to forward port 53 via the router) is to DEFINITELY upload the Firmware Update. TO LOAD that update, however, you need to use Internet Explorer OR an OLDER version of Firefox (2.0, not 3.0!0.
3 Suggested Answers
  • 1752 Answers
SOURCE: Router is a Netgear WPN824v3. The problem I am
Then the DHCP settings on the router aren't providing a good DNS to the DHCP client.
Posted on Dec 02, 2009
SOURCE: NETGEAR wirless router installation
You can use below steps to install router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put or address bar. press enter
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on lan ip setup under advanced.
6. Change the lan ip to and under use router as a dhcp server change the starting ip as and ending ip as, click apply and click ok for any popup message that arise.
7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
8. Power off the dsl modem and the router after making the connections.
9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
11. Access the router (
12. Login to the router (Username = admin Password = Password).
13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
15. Click Apply.
16. Logout of the router.
17. Open up another browser window and try to access internet.
Please rate the service positively if issue resolved
Thanks for using Fixya
Posted on Apr 04, 2010
How do i enable ports 25 SMTP and 53 DNS on a Netgear ADSL2
It depends on your router. First you need to login your router.
Then you need to find the port forwarding field. There you tell which ports to forward. In your case its 25 with TCP transport and TCP and UDP for port 53.
For each port you need to tell the router where to send the packages to. So you need to know the IP of the computer you want to get the packages forwarded to.
Some more detailed instruction which depend on the Router version (ADSL2 is not a specific version!) can be found here: or
Mar 14, 2011 | Computers & Internet
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
I want to hook up my ps3 using my 595u sierra wireless air card how do i do it?
You'll have to set up "Port Forwarding" on your router.
Click here to see a picture of which ports to setup under "Port Forwarding" for your router and the PS3.
Here are the settings that you should use when you setup your PS3 with a static IP:
IP Address: (Same as the one you used for Port Forwarding)
Subnet Mask:
Default router:
Primary DNS:
Secendary DNS:
Jan 13, 2010 | NetGear WGR614 Wireless Router
Connecting NETGEAR Wireless RouterWPN824 v2 to PC HP2009m tru Comcast Airrs Modem for use by Xbox360 in another room
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as:; Subnet mask as:
and Default Gateway as:
2. Assign Primary DNS Address as: and Secondary DNS
Address as:
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address
Click On 'Apply'.
10. Log Out of the Router Page.
Dec 30, 2009 | NetGear RangeMax WPN824 Wireless Router...
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Chances are that the router is set to manually assign an address if it doesn't receive an IP from the DHCP server.
I would first try removing all the wireless profiles and creating them again.
Also a windows update may have broken any firewalls you currently have installed so disabling them is also a good idea, then turn back on when you get it to work.
Dec 02, 2009 | NetGear WGR614 Wireless Router
How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Jun 30, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
    336 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
