Question about HP Photosmart C4280 Aio Printer
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have bents something, but i don't know. i can print photos just fine, but any other document, even in "best" has doubled letters. and yes, i have done all the cleaning and aligning solutions with no results.
  • 1,218 Answers
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Nov 08, 2010
Testimonial: "fixed two of my black ink problems. doubled letters and a horizontal line offsetting some of the lettters. thank you so much."
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Will lexmark 17 black inkt cartridge and a lexmark 27 color ink cartridge fit in a hp photosmart c4280 all in one printer and work properly?
Negative, but you may want to think about refilling your HP74/75 ink cartridges for your HP PS C4280 printer....it's actually quite affordable.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Jun 12, 2013 | Office Equipment & Supplies
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
I have installed colour cartridge 351XL and black 350 cartridge but my printer still says Print cartridges missing or not detected
Have you removed the shipping tape from the print cartridge? It covers the print head on the cartridge to protect them so they won't leak ink.
Nov 01, 2010 | HP Photosmart C4280 Aio Printer
Printer will not recognize new blk ink cartridge.
I think either the printer's scanner(or film as some call it) and/or the carriage is faulty. The signal cable that connects the carriage to the logic board could also be a suspect. Try replacing these items one after another and the culprit will be isolated. Good luck.
Jun 03, 2009 | HP PhotoSmart C4280 Laser Printer
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
HP Photosmart C4280 Aio Printer Logo
445 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
