Question about LG Dishwashers
I have an LG dishwasher, Model LD-2120WH and lately it starts" -- water goes in but it throws up a E1 message on the display screen, send off an alarm and stops
I've just solved the same problem on my 2120. It started when the pump motor bearing failed and continued after I'd replaced the bearing. According to my handbook the E1 fault is theoretically a water leak but practically it is that the pump is not delivering enough water. In this case the failed bearing had allowed the shaft to wobble about and damage either the rotor or the inside of the pump (it's sealed so you can't strip it). Solution was to replace the pump.
Paul H
Posted on Nov 28, 2010
I fixed the Error E1, 3 days ago in my dishwasher... actualy, it was easy: with the machine stopped, I pull the drain hose , and suddenly i felt a small squirt of water to my arm. The hose had two small ranks (crarcks). i just used insulation tape for plumbing, witn many turrns (a white one, whose name I do not remember), and then use another insulating tape with glue on one side, with many turns likewise. Solved! The error E1 disapear , and used the machine for 3 times now, without errors and dishwasher "stopings" . Hope my experience help you ... good luck. Rui Martins, Portugal,
Posted on Sep 03, 2017
Dishwasher LG ld-2120wh has a F on the Auto switch, what does this mean
it means that is testing the washing cycle , It uses only what it needs to use of your powerball dishwashing detergent by testing the water . The F is displayed while it tests the water in the dishwasher to determine how much detergent it needs.
Apr 15, 2014 | Dishwashers
Dishwasher LG ld-2120wh have F on the Auto switch, what does this mean
F is displayed when the dish washer is testing the water to see if more dishwashing powder should be used when in Auto mode. To do with saving the environment to use the least amount of detergent
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
917 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
