Question about Sony Ericsson W300 Cellular Phone
Hanged? or flex?
I tried to attach my w300i to my desktops usb port,then my computer had a long time processing it to make it appear on the screen "usb recognized",what i did soon after was i detached my phone from the usb port of my desktop and put it back in quickly..what happened after was it went white and it didnt turned on well since..when you turn it on it just turns white screened in an on and off sequence..what is the problem of my w300i and what can i do to make it fix?
    President:
  • 1,944 Answers
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
Posted on Jun 16, 2008
Usb ports wont work on a1217n pavillion desktop
None of them? Front or back? Turn on the computer and notice the screen to see what key ist says to hit to get into the Bios or System Setup during the boot process. Once you get in look to make sure the USB is enabled.
Hopefully you are not trying to put some new device into the port that might be too advanced for your system. Some systems can't handle things like a 1TB external drive.
Make sure you try something in the usb port that you know worked in the past and try different ports.
Apr 30, 2012 | HP Pavilion a1217n Desktop PC
Where do i insert a memory card from camera to transfer pix to desktop
If you have a builtin card reader else you can use usb cable or buy a card reader which is cheap about £1.
Jul 07, 2011 | Computers & Internet
I have 2 Lacie 2TB external drives. 1 of them does not appear anymore on my desktop it did the other day off and on. 1 or 2 times in the rebooting a disk formating pop up appeared saying it did not...
Try changing the USB port to connect it. Also try substituting the cable used to connect the errant disk. It may be a cable issue or a USB port on your computer.
Sep 08, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Problem with usb port don`t work
Step 1
Before you start working on the USB port, make sure that your device is not the problem. If the computer says that the there is a new USB device but that it cannot use it, typically there is a problem with the device's driver and not the USB port. If this is the case, your best option is to re-install or upgrade the device driver. Try inserting the device to another computer. If the device works, most likely the problem is with the computer and not your device.
Step 2
Try rebooting the machine. Rebooting a computer resets all of the software to the default state and will clean up many issues. The start up process also checks all of the devices on the computer and can sometimes fix a USB port. First shut down the machine. Connect the USB device up to the computer and start it. This reboot will sometimes fix a bad USB port.
Step 3
Try attaching the USB device on to another USB port on the same computer. If the device now works, the old USB port probably has a hardware or BIOS issue. Skip to step 5 to try to fix a bad USB port through the BIOS. Fixing a hardware problem on a USB port requires working on the motherboard which is typically more expensive just adding a new USB ports.
Step 4
Uninstall your computer's USB device bus manager. The device manager controls the USB access and sometimes gets corrupted. Fixing the USB device manager requires administrator rights on the machine. The best way to uninstall the device bus manager is to right click on your computer's icon and select properties. This will bring up the hardware settings for your machine. Click on the hardware tab and select the device manager. The device manager lists all of the devices on the computer. The next step is to open up the "Universal bus controller" option. Right click on all of the items under this option and uninstall them. Once all of the devices have been removed, restart the machine with the USB device connected. Upon reboot, windows re-installs the USB device manager. Most of the time, this will fix the USB port.
Step 5
The next thing to try is to check the BIOS. Restart the machine and enter the BIOS setup screen. You should check to make sure all of the USB ports are active. If they are, you should try resetting the BIOS settings to the defaults. The BIOS reset will sometimes fix USB port. But if it does not you will have to consider upgrading the BIOS. Upgrading a computer BIOS is very dependent on the motherboard manufacturer and you will have to visit your computer manufacturer's web site for detailed instructions.
Step 6
The last trick to try to fix a USB port is to repair your OS. Sometimes the USB drivers can get corrupted and break the USB ports. You can reinstall the system files onto the computer which should fix the USB port. Your data files should not be changed in this process, but it is a good idea to do a full backup of the computer ahead of time. In windows, an OS re-install is done by loading up the windows installation CD/DVD and selecting the repair windows installation. Just follow the steps and you often have a fixed USB port at the end of the process.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 12, 2010 | Dell OptiPlex 210L PC Desktop
Rocstor external hard drive does not appear in my computer win xp although message it was installed when I connected the usb port
Good morning! first, make sure your external hard drive is properly connected to the USB port, then try to start / restart your computer again, automatically the computer should recognized the attached external HDD. best regards.
May 02, 2009 | Computers & Internet
When I flip my Sony Ericsson W300i's up. The
thers summat wrong wit da ribbon cable u cant get dat fixed if u did it wud cost quite a bit happened to my phone
Apr 22, 2009 | Sony Ericsson W300 Cellular Phone
Hanging problem
ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
W300i or usb drivers ?
You can get the usb drivers from sony ericsson website, just follow the link below:
http://www.sonyericsson.com/cws/support/products/updateservice/w300i?cc=in&lc=en
Mar 14, 2008 | Computers & Internet
Sony Ericsson W300i Removing the Housing
The housing is difficult to do. You have to be careful to not rip the flex cable that connects the two pieces. Once you remove the orange button on the side you will see a blue circular type pin. You must push that in all the way while gradually pulling your phone apart. Also at the same time you want to watch to make sure the flex cable don't snag itself of the folding parts. It slides in one way and you must be careful to not rip it. It is kind of in an S shape and slides in very delicately. once you get this part then the rest is easy to do. I hope this helps some and good luck. And yes I do repair these and replace all the parts on these phones so I know how difficult it can be for the first time. If you have anymore questions or if you want me to elaborate more on this just let me know.
GOOD LUCK!!!!
Dec 08, 2007 | Sony Ericsson W300 Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
69 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
