Question about Car Audio & Video
Sony aftermarket radio installed into 1996 maxima with factory speakers. radio makes loud "pop" noise whenever changing stations or source. otherwise, it's pretty clear. pls help.
  • kylegraver
    kylegraver Mar 17, 2013
    have the same problem
  • kylegraver
    same car i have bose speakers stock, and mine does the same thing could it be the ground wires?
    Sniper:
  • 59 Answers
Does it just pop thru the subwoofers? If so I would guess its something to do with the rca wires.
Posted on Nov 08, 2010
My 2001 impala speakers are make a popping noise with key on or key off
factory stock radio:? , not custom aftermarket radio added and wired in to car wrong?
well unplug the radio connectors. does it pop now.
yes, then its not the speakers. popping.. how can they , not connected?
no, then , check for 12vdc at the radio power connector wire
with key pulled. (off)
got power on the radio now,. that is wrong.
use a rubber hose to your ear to find true object popping.
Jun 09, 2014 | Cars & Trucks
I put a replacement radio in a 1994 Olds Cutlass Supreme radio makes noise in right rear speaker when tuning in station.
Hi JPLP, A popping or 'motor boating' sound is usually a sign that one of the transistors is defective. As it happens only when tuning in the radio it is possibly in the pre amp stage. Regards John
Aug 19, 2012 | Cars & Trucks
1996 Ford Explorer factory Radio works but when i install the aftermarket radio no sound comes out from it what do i do ..??
Does it light up? Does it have a mute button? Does it have a mute wire for in vehicle phone systems? If so, it may need to be grounded to take it out of mute, or it may need to go to 12 volts + It depends on how the circuit was designed.
If those check out, or it lights up but no muting make sure the speakers are connected to the correct wires. Also check to make sure the speakers are not grounded. Two wires should go to each speaker. you can check the condition of the speakers with a 9 volt battery touched across the leads, you will hear a pop sound. make sure those two wires for each speaker are connected to the radio correctly.
Jan 23, 2012 | 1996 Ford Explorer
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
96 Nissan maxima -Loud Belt-like noise
try some belt dressing (spray in a can) you can get at any auto part supply,it worked for me
Jun 02, 2009 | 1996 Nissan Maxima
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
2000 maxima
Heres an easy fix for it, and can improve your sound quality, Change the radio head unit entirely. OEM (factory) head units are ****, and you can get aftermarket that accept OEM cd-changers.
Oct 13, 2008 | 1997 Nissan Maxima
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Mar 09, 2008 | Sony CDX-GT710 CD Player
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
