Question about LG Studioworks 560N 15" CRT Monitor
Monitor is not getting signal. - LG Studioworks 560N 15" CRT Monitor
Swap your power supply with a good one.
Posted on Nov 08, 2010
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
Getting a no signal when hoioking up to video card.
hook a different montor up to the same card and see if you get a signal. if you do change the input on the monitor not getting a signal. if this does not make the monitor get a signal your video input on the monitor is bad and needs o be replaced or repaired
Dec 26, 2009 | AOC Monitor
Monitor wont get any signal
it should be the problem with ram,
so remove ram from the motherboard and clean using lint free paper towel and inserted it back. this will fix the issue.
Sep 03, 2009 | Computers & Internet
Hi All, I'm using philips 15 inches monitor. After i press the power button on my CPU, monitor gets no signal. But sometime it get the signal without any issue.This is random failure. I plugged my friends...
HI,
This is not your problem, this is your monitor's problem, just kidding :)
This monitor require re-solding of point on its board. If you can do it, open it and check power circuit and data cable circuit and re-sold points. Hope this will work.
Regards;
Hassan
Jul 20, 2009 | Philips Computers & Internet
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
When I turn on my computer I getting no signal to the monitor.
I connect my monitor to my computer and I recieve no signal but my computer screen work just the other day, this problem come about when I disconnected my monitor to view on another PC. And now I rec onnect it to my computer and I don't get any signal.
Dec 28, 2008 | Acer AL1916W 19" LCD Monitor
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Acer monitor lcd
no signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable, eyo7 eyoifiok2005@yahoo.com
Feb 28, 2007 | Acer Professional P211 21" CRT Monitor
LG Studioworks 560N 15" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
