Question about Nikon D80 Digital Camera with 18-135mm Lens
I have a Nikon D80 which happens to over expose any shots that I take outdoors. I have tried manual and auto settings. I compared it with another D80 on the same scene and with the same exposure, my pictures look 10 times overexposed. I tried switching the lens but it made no difference.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
What about the Exposure Compensation setting? set to "0"
Posted on Jul 23, 2013
4 Suggested Answers
CanadaBruce
  • 58 Answers
SOURCE: Nikon D80 Exposure Count
Could it be that you are set in the "highlight" view?  Use the round selector in view mode to change the views.
Posted on Mar 09, 2008
  • 48 Answers
SOURCE: Blue corners when shooting in BULB
With the same exposure settings, you should get the same result. When using Bulb in Manual mode, you also need to be sure you have set the lens aperture to the largest opening (lowest number). And don't forget to set ISO to 1600. Since the D80 has shutter speeds as long as 30" (minutes) I recommend you use them instead of Bulb, unless you need longer.
The blue areas are heat noise from long exposure -- other electronic components near the sensor are generating heat from the constant current flow. Be sure you check your Shooting Menu settings to set Long Exposure NR to ON and also High ISO NR to HIGH.
Posted on Apr 04, 2009
  • 181 Answers
SOURCE: Have Nikon D80 with 18-200VR lens. Am getting
Please check your exposure value (EV) settings. You may have raised this and forgot to move it back.
You should be able to play with exposure also via the Shutter, Aperture and ISO settings
Posted on Jan 04, 2010
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the...
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Jul 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 won't allow use of auto ISO
Hi kathlag96, page 43 of the manual state that Auto ISO works in the Vari-Program modes. Page 88 item 7: explains Auto ISO does not work in the P, S, A, M modes
Jun 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 Digital Camera with 18-135mm Lens: My nikon d80 will not auto focus when I push the s...
The r11 is in the lower right of the top LCD or view finder that is in the D80 manual page 36 it speaks about the buffer. The r with a number is how many shots the buffer at that moment can handle. It is not an error message. For auto focus issue is the lens in AF as well as the camera?
May 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
Hi, My Nikon D80 is now kaing over exposed
This can happen if you have ISO control set to Auto and have spot metering selected, especially if it's set to spot shadow or spot highlight. Over exposure probably means it's set to spot shadow metering.
With spot metering the camera measures exposure from just a very small point in the scene, and so slight camera movements will cause the metering spot to wander onto different exposure settings very easily. If the camera is either set to use restricted apertures or shutter speeds due to program or lens limitations then it will compensate by adjusting the ISO settings instead
Never use auto ISO, just choose what you need for the conditions rather than using the camera's best (& usually poor) guess. Alsonever use spot metering unless you know why you're using it. The default multi-pattern metering is extremely accurate for most situations.
Please check the camera settings based on what I've said, if it fixes your problem then please rate my answer. If not then please add further details of which lenses and camera settings you're using and I'll try to help you further.
Oct 31, 2009 | Cameras
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blurry action pictures
The sport setting uses a faster shutter speed to stop motion. However, if you have the ISO set to a low number and try to take action shots in dim light, they will be blurry. Either use auto ISO or use a higher number such as 400 or 800.
Sep 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Apr 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Yellow/green tint indoor photo using auto portrait mode
Hi - You can download the Nikon D80 Guide to Digital Photography manual by clicking the link underlined in blue below:
Nikon d80
Firstly see page 58:
Try setting the white balance to fluorescent an compare. Also you could set your own white balance preset by shooting a white card as per page 59. Lastly you can play with the "tone adjustment" on page 80.
Let us know how you get on!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 11, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
52 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
