Question about Toshiba 55H70 55" Rear Projection Television
The bottom of ym screen has mutiple colors and a 3-D effect
    Sergeant:
  • 252 Answers
You need to do a convergence on your TV please watch this video for instructions.
Posted on Nov 08, 2010
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
When i type to ym chat window then i send i cant see my message and i cant read the message in ym also my offline message the window is blank what well i do?i used yahoomessenger 10
1. restart you sistem and running again your YM 10.
2. if not effect, sometimes on your windows Start-Up "MsConfig" any spywhere, you can Scanning with AntiVirus.
3. Antivirus Can't repair any system was broken, you must Re-installed your Yahoo Messenger.
Mar 01, 2011 | Yahoo Messenger
YM chat screen blank, I have done things below: - Font color confirmed black - All Scripting are enable - Have run regsvr32 wshom.ocx , jscript.dll , urlmon.dll , vbscript.dll - Have scan for...
Hello!
I see you have already troubleshot some possible solutions,the next bets thing would be to uninstall Y.M,restart you're computer and install Y.M again.
Hope this helps!
- AriGold
Nov 04, 2010 | Yahoo Messenger
How do i install ym for my se xperia10
Hi.
No standalone YM client for the Android handsets just yet but...
Go into your X10 main screen by tapping or dragging up from the bottom of home screen.
Find the "Market" app and tap it.
Let it load then tap the magnifying glass on the top "RIGHT" of the screen.
Type in "ebuddy"
Enter
It should now show you the ebuddy icon and a star rating.
It's a FREE app so just tap install agree and install.
ebuddy is a multi-format app so you can use it with YM, WM, AOL and others including facebook.
Have Fun. :)
Jul 20, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Windows Vista
What you need is Disable and Turn Off ClearType Fonts in Windows Vista
Windows Vista by default applies ClearType effect to the fonts displayed on screen, in order to improve the appearance of text on certain types of computer display screens, especially LCD flat-panel monitors. As ClearType text actually sacrifices color or chrominance details aspect of image quality for light and dark or luminance detail, some people may not like the blurry font style in ClearType. Here’s a easy way to disable or turn off ClearType in Windows Vista.
1. Right click on any blank spot of desktop, and then select Personalize on pop-up context menu.
2. Select Window Color and Appearance.
3. Click on “Open classic appearance properties for more color options” link located at the bottom of the page.
4. Click on the Effects button.
5. Do one of the following:
Uncheck (untick) the “Use the following method to smooth edges of screen fonts” box.
or
Select “Standard” to replace ClearType in the drop down list under the above title.
6. Click OK, then click Apply, and finally finish with clicking OK again.
To enable or turn on ClearType effect again, simply reverse the setting in the Effects step.
< Please Rate :) >
Apr 12, 2009 | Compaq Presario R3000 Notebook
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
RGB colours all over
it is due to magnetic effect in television due to problem in degaussing circuit. solution 1 remove the things which have got magnetic effect like speaker, phone etc. 2 change the direction of tv. 3 do not change the direction when tv is on. 4 call tech. to degauss it by using degaussing coil at your place. 5 it is not a major problem.
Sep 30, 2007 | Televison & Video
Toshiba 55H70 55" Rear Projection Television Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
