Question about Kenmore Washing Machines
How Do I replace the front bellows seal on the Kenmore Elite Front load washer
  • 5,911 Answers
Here ya go, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the instructions thoroughly before starting. This is a fairly straight forward and simple repair job. If you require further assistance, go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
Posted on Jun 16, 2008
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
The door seal in my kenmore elite HE3 is ripping...is it replaceable?
Yes, it is. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
Replacing the rubber seal on the door
The following link explains how to replace the door bellow on a Kenmore Elite front loader:
NOTE: Review some of the testimonials as well. One user (DGBG) offers a quicker way of replacing the bellow if you're willing to give it a try.
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
Door seal tangled in wash load.
It sounds like one of your retaining clamps may have come loose or something sharp may have snagged the door bellow and pulled it loose. You will need to inspect the bellow for any potential rips or tears and ensure the front and rear clamps that hold it in place are still intact and useable. You may be able to simply reattach the bellow and won't require parts. The following link explains how to replace a door bellow and lists the steps required for accessing and installing the clamps:
This isn't difficult, but it can be tedious. If you require replacement parts, you can order from any of the following web sites:
repairclinic.com
The part numbers for Kenmore Elite are as follows:
Door Bellow: 8181850
Front Bellow Clamp: 8182211
Rear Bellow Clamp: 8182210
All these sites offer great service if you determine you need parts. Shop around for the best prices.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
Tub seal relacement method
The following link explains the step-by-step procedures for replacing the door bellow on a Kenmore Elite HE3:
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Kenmore 44072 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Jan 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
479 people viewed this question
Sal De
fordexpert
Robert Rankin
