Question about Panasonic TCP46S2 TV
What are the best settings for calibrating panasonic plasma TCP46S2 ?
2 Suggested Answers
  • 1779 Answers
SOURCE: Panasonic VIERA TH-37PX80B 42" plasma telly
What ever sounds the best to you!. If you have a particular question regarding sound, let me know?
Posted on Jun 24, 2009
How do I calibrate my Panasonic TC-P55ST50 for the best picture quality?
Tweak the factory default settings until you are satisfied with the results.
Oct 15, 2014 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Find the best audio setting for panasonic tv
There isn't a best audio setting. We recommend you simply use the TV's audio menu to manipulate the sound until you find your preferred values.
Mar 11, 2014 | Panasonic Viera Plasma TV TC-P46X3
I want to know best picture settings for my panasonic TC-58LE64 LED VIERA SMART TV
Select the default picture settings first. Then adjust the color according to your taste. It will be the best picture.
Sep 07, 2013 | Panasonic Viera TH-42PX80U Plasma TV
Can I get the best calibration settings for this model?
Hi, The best calibration settings vary TV to TV because it depends on what looks good to the person as well as the type of room you're in. If you can't seem to find settings you're happy with there's many services that can professional calibrate TVs to your liking.
Aug 29, 2011 | Samsung PN51D490 3D Plasma TV
I have a sony kdf-46e2000, there is a pinkish stripe on the top and bottom of the screen, what is causing that?
Looks to me as an serious (but not uncommon) PSP board problem with Sony plasmas. Contact a Sony service center.
What problems have people had with quality control on these displays? Are they covered under warranty?
  1. Certain displays emitted an extremely loud buzz. This was covered by warranty repair.
  2. Certain displays had a problem with the Y/C delay on their S-video input. This was also correctable.
  3. One person reported red vertical lines on his display. Was this covered by warranty? Was it an input problem or a pixel problem?
  4. Afew bad pixels here and there are not covered under warranty. Largeclusters are generally covered. It's up to Sonys discretion. On the plus side, however, bad pixels are becoming increasingly rare. Mostpeople are reporting no bad pixels at all!
CALIBRATINGWhat needs to be calibrated on a plasma?
You needto calibrate most of the same things that need to be calibrated onother displays. About the only things that don't need to be done areconvergence and geometry. You can usually tinker with picture size andposition, but there's no need to deal with keystone or pincushionadjustments, etc.What is white level? What is black level? How are they adjusted?
Theadjustment for white level is usually labeled "Picture" (as onPanasonics) or "Contrast". "Brightness", on the other hand, refers tothe black level. Yes, this is apallingly counter intuitive. This FAQuses the terms "white level" and "black level", since they betterdescribe what you're actually adjusting, and they're the terms used byAvia and Video Essentials.
How do I adjust hue and saturation?
In another mysterious choice of terms, hue is controlled by the "Tint" setting,and saturation is controlled by the "Color" setting. This FAQ uses theterms "hue" and "saturation", since they're the terms used by Avia andVideo Essentials.
How do I set the white level on a plasma?
Youset the white level by adjusting the "Picture" setting. You will needto use a different test pattern than you would for a CRT. For both plasma displays and LCD displays, you should use the 10 IRE grayscalestep pattern. There are two criteria you want to match on your plasma.
First,you need to make sure the white level is low enough that your displayisn't thresholding (or clamping) bright levels. You should set thewhite level low enough that you can see each of the 10 IRE stepsdistinctly. The Sony seem not to exhibit clamping (in my limitedexperience), even at factory defaults, so this criterion may not beterribly useful.
Second, for the health of your display (e.g.to avoid burn-in), you should turn down the white level. Just becauseyour display can display blindingly bright pictures doesn't mean that it should. Plasma displays should be set between 21 fl and 25 fl light output; the Sony comeout of the factory at about 30 fl. On one ISF-calibrated Sony, 23fl was roughly equivalent to a Picture setting of -20 (in the usermenu, not the service menu). To set this precisely you'll need to bringin a calibration specialist, but you can do a lot of good by justdialing down the white level a lot. After seeing the display at 30 fl,23 fl will see very dim. But after a while, you'll find that 23 fl isplenty bright.
How do I set the black level on a plasma?
Youset the black level by adjusting the "Brightness" setting. You can usethe same test pattern you would use for any other display.
How do I calibrate grayscale (calibrate the color temperature)?
Unfortunately,this is one you can't do yourself. You need special equipment tomeasure the color. In fact, most ISF technicians lack the equipmentspecific to plasma calibration (a $15K gadget known as aspectroradiometer). But even the standard color measurement equipment(which calibrationists do have) will do a great job.
Thatsaid, one person who had his Sony display calibrated by an ISF specialist said that the Cinema / Warm setting was reasonably close to6500K out of the box. Using that setting is probably the best you'll doon your own.
If you're really determined to screw up yourdisplay, the RGB drive and cutoff settings in the service menu are used to adjust the color temperature.
How do I adjust the color decoder?
There are several issues here. Generally speaking, the Panasonic decoder seems topush blue a bit. The R-Y Axis Angle and B-Y Axis Gain in the servicemenu are used to correct this behavior.
There used to be aproblem on some Panasonics with the Y/C delay on the S-video input. Seethe Quality Control section for more information.
How do I adjust the gamma?
On the industrial model, there is a set of Advanced picture settings. Go to the Picture menu, turn Advanced on, and then hit the down-arrow. In the subsequentmenu you can adjust quite a few parameters, including select from a fewgamma settings.
This advanced menu appears to be missing from the consumer model.
How do I calibrate my consumer model given these missing menus?
Thereis apparently a way to activate these menus. Perhaps you can find acalibrationist or Panasonic technician would can turn them on longenough to do the calibration.
What's the overall calibration procedure?
In general, the order Avia sets out is the correct one. A more complete list is:
  1. White level (picture)
  2. Black level (brightness)
  3. Repeat (1) and (2) until you have a good balance.
  4. Grayscale (requires special hardware and mucking about in the service menu)
  5. Sharpness
  6. Hue and Saturation (tint and color)
  7. Color decoder (requires use of the service menu)
  8. Repeat (6) and (7) for red and green until you have a good balance.
SERVICE MENUHow do I access the service menu?
In a word, don't. See the service menu warningabove. If you're bound and determined to make use of the service menu,buy the service manual. It contains more than enough information foryou to ruin your display and/or kill yourself.
Aug 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jun 24, 2009 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
42" sony plasma wont power on
I don't think Sony makes a Wega Plasma. Sony did make a plasma about 7 years ago but it wasn't Wega. Are you sure it's not Grand Wega SXRD or Lcd type
Apr 13, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony projection Tv KP-65XBR10W has no picture or sound
I had a Sony recommended serviceman come in to analyze te same problem for me. Turned out to be a major part called the 'D' board. Cost for part around $400 if it could still be gotten and at least $300 in labor. Goodbye TV! My money will be better spent on a replacement LCD/Plasma TV since prices are dropping and picture quality will be dramatically better than the old beast.
Dec 30, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony Plasma KDE-P42XS1 Television
We had the same problem discovered it was the TV bulb was going out. Thought the light would blink before that happened according to the book but found out it only blinks when it goes out completely. Buy the bulb and put it in yourself, it's easy and will save you at least $100.00
Dec 29, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Color calibration
I'm sure that there is a reset on the menu for the color, then you can set to your likings.
Dec 26, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TCP46S2 TV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
