Question about Patton PUH680-U Utility Heater
Heating element - Patton PUH680-U Utility Heater
    Genius:
  • 1,015 Answers
There should be a fuse located on the back towards the bottom. It should have a screw in cap holding fuse in plase.Remove fuse and see if you can tell if its blown. If your not sure you can try new fuse of right size and amp rating.Amp rating should be stamped on end or around base of fuse. If this helps thats great. If not and you think heating element is burned you probably better off to just get new one as the price of new element and possible other parts will cost you as much or more than buying new. Hope this helps. Thanks
Posted on Nov 08, 2010
My machine stopped heating but everything else functions. Can that be repaired?
There is an element in the bottom.
Google
make model element
They appear to be available
Find Bread Maker Machine Heating Element ' eBay www.ebay.com > ... > Small Kitchen Appliances > Bread Machines Bread Machine Parts Finder is the place to find a Heating Element for your breadmaker. Bread Machine Parts Finder has a breadmaker Heating Element ...
Bread Machine Heating Elements - By Bread Machine Parts ...
www.breadmachinepartsfinder.com/catalog/25 Element-ABM300, Welbilt Bread Machine Heating Element ABM300, $9.99. Element-ABM300, Welbilt Bread Machine Heating Element ABM300-1, $9.99.
Bread maker Heating Element ' Bread Machine Parts Finder
www.breadmachinepartsfinder.com/taxonomy/term/696 Skip to main content. Bread Machine Parts Finder logo. Main menu. Home · Comments. You are here. Home. Bread maker Heating Element. Subscribe to Bread ...
Bread Machine Heating Element - Alibaba
www.alibaba.com > Home Appliances > heating > heating element Bread Machine Heating Element, Buy Various High Quality Bread Machine Heating Element Products from Global Bread Machine Heating Element Suppliers ...
What To Do If Your Bread Maker Stops Working? ' Mr ...
www.mrbreadmaker.co.uk/.../what-to-do-if-your-bread-maker-stops-wor... Apr 12, 2013 - Read our guide on dealing with common bread machine problems. ... are colder and the heat element is not working right then your bread will ...
Morphy Richards Breadmaker Parts ' Partmaster
www.partmaster.co.uk/morphyrichards/breadmaker/catalogue.pl?... Morphy Richards Breadmaker parts - repair your Morphy Richards Breadmaker with a Breadmaker spare part from Currys Partmaster. Worldwide and Next Day ...
Morphy Richards 48280 FastBake Bread Machine Heating ...
www.fixya.com > ... > Morphy Richards 48280 FastBake Bread Machine ...heating element for my SDYD 250 bread maker ? After three uses, the unit no longer heats up......I think it is either a bad control board, or a defective heating ...
Breadmaker Spares ' Spares & Accessories
www.morphyrichards.co.uk > Spares & Accessories Buy a Morphy Richards Breadmaker part. Spare parts for Morphy Richards Bread machine.
and a video of how to change.
How to replace the element in a breadmaker - YouTube
How to replace the element in breadmaker
Feb 06, 2016 | Kitchen Appliances - Others
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    How do you replace the bottom heating element
    Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
    To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
    Charlie
    Jan 09, 2011 | Ovens
    Tip
    How to Replace Heating Element from a Maytag Dryer?
    The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
    2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
    3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
    4) The heating element is located in the cabinet.
    5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
    6) Locate the heating element cabinet and remove the screws holding the cabinet.
    7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
    8) Remove the connector carefully from heating element with the help of needle nose plier.
    9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
    10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
    11) Remove the old heating element and insert the new heating element.
    12) Connect all the wires as it were connected before.
    13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
    Element in oven sparked at corner and now will not heat
    The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
    Charlie
    Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
    Not heating up
    Hi.
    If one of the heating elements is not heating at all, then replace the heating element. You can test the heating element reading Ohms with a multimeter. You disconnect element and read impedance with multimeter set at Rx1. If the element has no continuity, and the circuit is open , then the element has blown. In that case you get no heating at all on one of the elements. Check if either broiling or baking element is not working.
    If heating is poor, then it is the sensor probe.
    In some case replacing the probe does not fix the problem. In that case it is faulty control assembly. Usually it is the temp probe.
    Here parts and diagrams.
    Regards.
    Oct 24, 2009 | Maytag MER5775Q Electric Kitchen Range
    Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
    Hello there
    Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
    Best regardss michael
    1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
    1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
    2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
    3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
    Oct 15, 2009 | Whirlpool Dryers
    Rowenta DX-8800 will not heat. Location of heating element?
    The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
    Dec 30, 2008 | Rowenta DX-8800 Iron
    Patton PUH680-U Utility Heater Logo
    117 people viewed this question
    Top Patton Heating & Cooling Experts
    Mack Baxter
    tractorman44
    tractorman44
    Jay Finke
    Jay Finke
    Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
