Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE Arcitia refrigerator ice maker makes ice but sometimes the ice in the bin starts to melt and drips down inside the freezer and makes big icicles.
  • 478 Answers
You have a leaking valve allowing to much water into into the tray. Its fairly easy to change out. It could also be the defrost terminator is allowing it to stay in defrost too long. If it is only the water, yet ice cream stays hard, it is for sure the valve which is about $30.00. It is located in the back down at right corner. just pull off plugs and replace with new one.
Posted on Nov 08, 2010
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
The ice maker stops making ice, and the freezer goes into a melt-down mode. This goes on for days. Sometimes, I buy a bag of ice, pour it into the ice maker bin...and PRESTO, the ice maker begins to...
you may have a p c board failure . it has not completely it will . the board gets stuck in defrost and you have a melt down . ( main board d wr49x10152 ) / if not the board ck when it hapens the evap fan in back of freezer .. .. also ck for frost in back of freezer .. mm
Dec 17, 2009 | GE Profile PSF26PGSBB 36" 25.5 Cu. Ft....
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
139 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
