Question about HP DeskJet 970cxi InkJet Printer
I just replaced the color ink cartridge on my deskjet 970 and now it only prints in purple. what can i try?
  • 1,218 Answers
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 08, 2010
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    HP 970 Cxi. Problems with colour printing. Ink cartridge is new
    I have the same problem. I suspect the ink cartridge part # 78 that you and I bought has problem. I plan to return it today to the vendor.
    Nov 15, 2009 | HP DeskJet 970cxi InkJet Printer
    Printer is printing wrong colors
    Make sure it's the right ink cartridge for that model printer.
    Check if any of the colors is out
    Try running a calibration on the printer to make sure heads are lined up properly.
    Link to the manual - Aligning print cartridges is on Page 70.
    http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
    Apr 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    New tri color ink cartridge will not print red
    Probably bad, there's actually no way to check ink levels.
    Jan 22, 2009 | HP DeskJet 960c InkJet Printer
    Urgent printing!
    Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
    Nov 02, 2008 | HP DeskJet 970cse InkJet Printer
    HP Deskjet 6940 not printing after replacing ink cartridge
    My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
    Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
    Printer Prints Blue Test Page but not in black
    Your color cartridge is probably empty as well. you can go to>control panel>printers and faxes> your printer >right click on preferences then click on services. Do all of the maintenance possible on your cartridges and see if that helps. Are your cartridges HP cartridges or generic refills?
    Apr 22, 2008 | HP DeskJet 810c InkJet Printer
    Problem with color cartridge
    Your ink cartridge opening may have dried up. Try replacing the catridge with a new one. Should resolve te problem.
    Mar 19, 2008 | HP DeskJet 970cxi InkJet Printer
    HP DeskJet 970cxi InkJet Printer Logo
    124 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
