Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Canon mp250 series can i print only in black and white i ran out of color ink.
  • 1,218 Answers
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 08, 2010
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
I have a Canon PIXMA MP250, and it's printing black and faded lines alternatively. (one line black, one line faded black...), sometimes involve blue too.. Anyone can help?
First, are you running low on those ink colors? If not, possibly print cartridges need cleaning. If printer has separate print heads, they made need cleaning.
Lastly, print head(s) may need replacement.
Dec 08, 2014 | Canon Pixma MP250 All-in-One Color InkJet...
Where is the printer head on a canon mp250 printer?
open the snanner lid in printer powering on then the cartridge cradel will move to middle then open the both color and black cartridge and look the down side of the cartridges you will look some glazed white part .that is the print head which is metallic thin plate.when electric apply on it it heat and melt the ink and create some vaporize condition in the cartridge then air flow from the cartridge and spray the ink on paper.
May 18, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
My Canon Pixma MP258 printer can't print the red color but other colors are okay.When I print out any words or pictures that needs red color,it becomes green color.I don't know what's wrong...
Solution
1. Press START - Devices and Printers
2. Right-click the Canon MP258 series - select Printing preferences
3. Click Maintenance - Cleaning
4. Select All Colors BK, C, M, Y - Execute
5. Wait until the process is finished (Do not start another operation until the cleaning has finished).
6. Click Print Check Pattern OK
If the results print out like this, there are two possibilities:
1. Red ink in the cartridge runs out. Solution: injecting with red ink
2. If the red ink has been filled, and check pattern is still not out, meaning the color cartridge error.
Solution: replace the cartridges
Oct 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Can't use black cartridge only to print
Unfortunately it is all true.
Personally I would stay away from Lexmark, I am a Canon fan, the MP520 looks real nice, but it's personal choice at the end of the day.
May 29, 2009 | Lexmark X2600 InkJet Printer
Color printing
If your using windows OS go to control panel , then printer and fax icon open it you will see canon printer series listed right click on it and go to printing preference tab ,check print all documents in black and white click okay and then try to print....
Good luck...
Feb 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Help me pls...
First of all to make your ink last longer you need to be using the Canon PG-40 and CL-41 instead of the Canon PG-30 and CL-31. The 40's are the higher capacity versions of the 30's. If you mean to ask why your color cartridge is going empty when you don't print much color, it is because when you print in black and white your printer mixes in some color with the black. There is no way to stop your printer from mixing color ink with the black.
Oct 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
1,774 people viewed this question
old marine
old marine
