Question about Sony KV-13VM40 Combo
It just completely stopped working. No picture, not sound, not buzz... All 3 red LEDs on the front continuously flash 2 blinks. Is it repairable? Thanks B
    Sergeant:
    Champion:
  • 293 Answers
Power supply problem.need for repair.
Posted on Nov 08, 2010
    Problem Solver:
Power ok bot no video and sound no raster
Posted on Jul 15, 2011
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
No Picture No Sound
First look for Bad Capacitors on [power supply board,if anyone of them is puffed up on top they are bad,Then if you do not have any bad caps How old is the Lamp in Set? if TV recycles 3 times for turn on and you have 2 greenlights on front and one red light---- lamp needs to be replaced.
Jun 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
GOOD LUCK, EVERYONE!!!
Mar 12, 2009 | Dell 1700n Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony KV-13VM40 Combo Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
