Question about Microsoft Xbox 360 Console
No video output, just sound
Tried the RT+ Y reset and that didnt work.
Is the overheat idea a good idea? It sounds like a few people have made it work.
    Problem Solver:
  • 9 Answers
Try the overheat trick only if you are off the warranty, it's risky. It can lead to other problems.
Posted on Jun 16, 2008
  • 43 Answers
Well first make sure if you have a av cable that has both component and regualr avi jacks that the cable is set to right setting
HD - blue,red,green, and audio (red n white)
TV - yellow and audio (red n white)
should be a switch on the thick part the connects into the 360
My ps3 has no picture but has sound
you can try this..
leave a testimonial if it works.
if it doesn't write back and we will try another idea I have.
From the PS32_bing.gif main menu:
1. Settings->Sound Settings->Audio Output Settings
2. Change it from HDMI to Digital Out (Optical). I do NOT have optical hooked up on my PS3, so if you have it hooked up, you may want to unhook it.. probably shouldn't matter.
3. I left what was defaulted: "Linear PCM 2 Ch. 44.1 kHz" and 48kHz
4. Right on the D pad (X selects/unselects options) to move to the next screen.
5. A confirmation page, hit X to Enter, saving the changes.
6. Start up a game, you shouldn't hear any sound (as expected)
7. Exit the game, then go back to Audio Output Settings and switch back to HDMI. I selected "Automatic" for "method for setting the output format."
8. A confirmation page, hit X to Enter, saving the changes.
9. Start up a game, you should now hear audio with your game (once again).
My issue I believe was caused because I had been using a different TV2_bing.gif for a while. Somehow, when I switched back to my original TV, the settings did not automatically reset back.
Good Luck!
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Xbox 360 Video not work has sound
maybe one of the sound cords(yellow,white,and red)tops which is gold, can be loose are off.
Aug 07, 2009 | Microsoft Xbox 360 Console
No picture but have green light
  1. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  2. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
May 24, 2009 | Video Game Consoles & Games
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
Sound no video
Hello. There are a few causes for this. I will list a couple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Help no picture or output
Hello. There are a few causes for this. I will list acouple solutions for you.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
No video or sound
Hello.
Most likely this is an output problem. But I have had 1 PS3 that had a bad hard drive and it wouldn't even load to the XMB. So try another hard drive and see if that works. Even a swift smack to the old one may work. If that doesn't work try the video out reset.
Hope this helps. Good luck!
Aug 19, 2008 | Sony Playstation 3 (PS3) Console
RE: No Picture
Ok,
Then it is a hardware issue.If you have tried the switch, tried multiple cables, and tried it ondifferent tv's and it still does not work than this sounds link theknown X-Box 360 video problem.
Red Ring of Death problem is that the GPU(Graphical Processing Unit) has a tendency to overheat, which wouldmake sense why you get no video, since this is the internal componentthat sends out video through your a/v cables to your tv. The Sound cardand motherboard probably still work, so that is why you would still getsound.
So the only solution is to get it serviced.
You can also check out the below link.Just click on it.
http://www.engadget.com/2007/06/24/xbox-360-owners-reporting-blank-video-output-issue/
Aug 13, 2008 | Microsoft Xbox 360 Console
PS3 NO VIDEO
Aug 05, 2008 | Sony Playstation 3 (PS3) Console
Picture but no sound
it happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
