It cant find other devices even other device is already switched ON
  • 320 Answers
Check in the bios setup if all the devices are enabled.
Posted on Nov 08, 2010
Cant connect the sony rdp-x60ip to my computer via bluetooth
Press and hold the bluetooth button until it beeps, then it knows its looking for a new device.
When it is just flashing it is looking for a device it already knows.
Once connected it will stay on.
Feb 03, 2013 | Sony Rdp-x60ip Ipod Iphone Bluetooth...
I cant fix my webcam logitech v-uam27a p/n:861210 for win7 64bit
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 17, 2013 | Logitech QuickCam Computers & Internet
I noticed i have wifi in my laptop through my device manager but cant turn it on
some of the wifi featured laptop is software dependent and hardware dependent,,,means if software dependent you must have a software driver or compatible driver for it...even though it in your device manager....detected.... if hardware dependent ... find a switch or lever / slide switch or on the keyboard ...assuming it is enable in the setup program of your system...to make it operate....simply put ... you have see a bus but i has no driver....it cant run...the bus cant run itself...
Aug 19, 2011 | Acer Travelmate 2200 Notebook
My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Jan 27, 2010 | 3Com 4200 24-Port Ethernet Switch
Is Termination Necessary?
Usually, SCSI devices come with the termination built into the device. Older devices actually had two or three terminating resistor packs plugged into the card or drive circuit board. More modern ones have DIP switches to turn the termination on or off.
Essentially, on a SCSI daisy chain ribbon cable with multiple connectors, only the first and last physical device needs to be terminated. Usually SCSI devices come from the factory already terminated. If you have only one device to connect check and see if there is a DIP switch to change. I would go ahead and connect it. If it works, it's probably already set properly.
That said, I have worked with daisy chains of SCSI devices where a particular device would only work if it were terminated even if it was in the middle of the chain. s
Jul 10, 2009 | Adaptec Ultra160 Scsi 29160N (1835200)...
My blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Feb 09, 2009 | RIM BlackBerry Bold Smartphone
Media converter
The reason it says connect a device is because your device is not been recognize by windows properly..
What i would recommend you to do is to uninstall the device and reinstall it back...tou uninstall it...assuming that you are running windows xp1.gif...click on start, right click on my computer and go to properties..you should have your system1.gif properties open then click under hardware1.gif then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives1.gif and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer and check to usb mode..it has to be under MTP mode or auto....after you check the mode open up your windows media1.gif player click on tools, options and click under privacy...clear the history4.gif and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..Follow the link below to obtain the driver for your device..Select your device model and operating system1.gif.....
http://www.sandisk.com/DriverDownload/index.asp
I hope4.gif this helps4.gif..
Please rate accordingly
Thank you
Computerrep
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
Iriver U10 - deleted files stay on the device list
load ur iriverplus3, go to Tools -> Portable Device -> Update Database
worked for me :) gl
Oct 31, 2007 | iRiver U10 Digital Media Player
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
