Question about Toshiba 30DF56 Television
Only picture is a red screen - Toshiba 30DF56 Television
  • pyed75 Nov 08, 2010
    There is sound when on but it will immediately turn off. Mt husband thinks it is in the high voltage circuit or the fly back .We were looking for the manuals so he could fix it . He has done things before .
    President:
  • 2,777 Answers
Is this the case for all inputs / all channels? Meaning when watching TV, a DVD, anything.. it is always just a red screen, no display whatsoever?
Do you get sound out of the TV just find, or no sound either?
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    The high voltage circuit is definitely a good place to start, something with that flyback sounds like the issue for sure.
    Let me know if you need more guidance but it sounds like he knows what he's doing there...
    Tim
60p8342a philips tv picture looks red sound is fine
go to a unused video input and turn color off----screen there should not be red or even somewhat red, if it is the red screen control may have to be lowered just slightly.
Dec 04, 2012 | Televison & Video
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Dec 02, 2012 | RCA HD56W58 56" TV
My LCD Samsung tv screen I red instead of black and the picture has waves of red
Sound like a LCD panel problem, but get it diagnosed to be sure.
Sep 04, 2012 | Televison & Video
Turn the tv on picture come on all red and fuzzy and then couple seconds later tv turns off and then turns back on with no picture just red screen then turns off and wont turn back on for ten min
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
Apr 13, 2012 | Televison & Video
The screen gets red with no picture. so i openned up the back and noticed that the green bulb or picture tube whent iut out after 5 minutes.
yes u have bad picture tube but is not the green is the red , the red picture tube id over voltege , thats way u had red picture ,
Aug 26, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Toshiba 30DF56 Television Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
