Question about Kenmore Washing Machines
We have a kenmore quite pack 4 (he3t) were getting a beeping code. First a F then DL. Can you tell us what this mean and how we can fix it?
  • Kenmore Master
  • 1,902 Answers
Hello
F DL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. However, you can also try to clean the door lock mechanism and blow some air with the help of hair dryer. Please get back to me if you have any other questions.
Kevin
Posted on Nov 08, 2010
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2011 | Kenmore HE3T Washer
Getting a code of dl then f on display
'dl +F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 21, 2011 | Kenmore HE3T Washer
Error message dl F-what does this mean?
door lock error replace the door lock if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation thanks again Rick
p.s if after you replace the door lock assembly and you still have the same code you would then have to replace the ccu (main computer board ) but most of the time the door lock assembly fixes this problem thanks again
Rick
Dec 19, 2010 | Kenmore HE3T Washer
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Kenmore he3t front load washer doesn't turn on, only two beeps. I've tried unplugging it and same result.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
F-DL problem
sounds like the control board
May 12, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
ERROR CODE
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
