Question about John Deere Tractor 1020, 1520, 1530, ITJD37
I cannot remove the shaft connecting to the pto from a 54c deck on a x475 tractor
  • 3 Answers
SOURCE: ford 8n tractor.when i put a load on the pto , it pops off
Your PTO shift houseing is going out. I just repairs the same problem. You have to seperate the cases just in front of your lever to engage your PTO. The shirt fork is bent. Go to http://www.just8ns.com/index2.htm for parts and they also have a number on there sit for technical advise.
Posted on Aug 26, 2009
huffman49
  • 235 Answers
SOURCE: John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Posted on Apr 11, 2010
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
d_hubbs
  • 270 Answers
SOURCE: I have a 2510 John
Hi, I'm David .Hope i can give you some help.
First of all I beleive if you Make Sure you Don't Hahave the Clutches Backwards,Its Easy to do this.To line them Up your going to need a Helper,Trying this by your self will were you out.
Check to make sure The Splines are the Same as the Old Clutches.Includind the amount of Teeth in Each Clutch Have Got to be the Same.
Second make sure you have Plenty of Slack in your Clutch Adjustments.Remember you just removed a Work set of Clutches.So you'll need to Back off The Clutch Adjustments.
To give you plenty of Slack.You might also want to See if your Dealer Has a Pilot Tool or Clutch Alingment Tool to Help you .
Sir I hope i've Helped you.
Please let me Know by Voting on The Quality of my Solutiuons. Thank You:
Posted on Sep 23, 2010
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
My pto engages on the highest level for my deck on my mtd lawn tractor. Highest my deck will go is 5. But when I put it to 4 ir even 3 the pto cuts out. But as soon as you return it to 5 it starts
Owner's manual? no manual, try for both owner and Repair manual on manualslib.com
Wild guess, the angle of the PTO drive shaft related to the height of the deck is causing a problem. Perhaps it's binding and won't turn, or pops out because of the binding and load. Perhaps the drive shaft is not "locked" on for some reason, with pins or
another device. Perhaps the sliding portion needs lubrication.
Apr 06, 2015 | Mtd Garden
We are trying to hook up to the tractor a 466 john deere silage special to the tractor. My dad died and we are new at this
do you have the pto shaft connected? on some tractors the pto has a cover that has to be removed and a push pin that will allow the shaft to slip over the pto spline on the tractor then push it back to lock it on. if i can help my email is derrikhamby@yahoo.com
May 31, 2011 | Computers & Internet
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Apr 03, 2010 | Garden
Taking lawn mower off john deere 455 tractor
Undo the lever in the front by pulling it out and then rolling it downward to release the front of the deck [lower it to the ground before you start].Once that bracket is off you need to remove the drive shaft by pulling back on the lock collar on the shaft and then pull off the pto shaft.Now pick up the rear of the deck slightly and pull out the c hangers in the rearof the deck just ahead of the back wheels.Jack up the left rear end to make it easier to pull the deck out from under the tractor.
Nov 19, 2009 | Cars & Trucks
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
The drive pulley above the PTO won't come off the crankshaft
Hello bob2kat:
>>Have you Removed the Allen Lock from the Pulley?
>>Did you Clean the Crankshaft with Sandpaper before trying to Slide the Pulley Off the Shaft?
>>Thanks.
Respectfully
John
Apr 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere Tractor 1020, 1520, 1530, ITJD37 Logo
41 people viewed this question
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
