Question about Sony STR-DE525
Help I have a Sony STR DE 525 Amp/receiver abd DVD Player. When the power is plugged on it displays PROTECTOR. Could you tell me wher the possible problem may be?
  • 3 Answers
Check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Posted on Jul 17, 2008
I have a Sony receiver model Str - de 435 it constantly flash Protector and I tried everything to fix this any ideas
The protector indicator usually indicates that one of your amplifiers has shorted output transistors. This is not a user repairable problem and the amp will have to be taken into the shop for service.
Mar 21, 2015 | Sony Audio Players & Recorders
This amp wwhen turned on, dosplays 'PROTECTOR' on teh display, what is this telling me?
Disconnect all the speakers and unplug it for 5 minutes. Then turn it back on without any speakers plugged in. If it doesn't say protector, then you either have a shorted out speaker or wire. The amp is in protection mode which is designed to keep it from burning up. If it still says protection, then it will need to be repaired as it is too late.
Dec 19, 2009 | Sony STR-DE535 Receiver
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
Sony str de345 in protect mode
If PROTECT , PROTECTOR or a P is flashing in the display of the A/V receiver, there may be an incorrect connection or an improper setting. Try following these steps to resolve this issue:
IMPORTANT: If model-specific information is needed to complete any of these steps, refer to the instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
NOTE: Because each of these steps represents a possible solution to this issue, check the A/V receiver status after completing each step.
  1. Check the speakers and speaker wires for proper connections.
  2. Reduce the volume level. IMPORTANT: If the A/V receiver is used at maximum volume level, it may enter the PROTECT mode. Maximum volume listening will cause the A/V receiver to run very hot and may drain the output capacitors.
  3. If applicable to your model, disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the A/V receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some A/V receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for approximately 1 to 2 hours to reset the output transformers.
Oct 22, 2009 | Sony STR-DE345 Receiver
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
My sony str-d1o15 says protector
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 20, 2008 | Sony STR-D1015
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
Sony STR-DE525 Logo
415 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
