Question about Sharp AR-651 Laser Printer
Copied document shifts down 1/16 inch
All my copied docs seem to be just a little lower than the originals. Any help appreciated.
Steve
  • 197 Answers
Hmmm...and the original is right on the mark on the glass?
Posted on Jun 16, 2008
The out copied paper is not fully copied
First turn off at the wall outlet and count to 20 and plug back in to reset.
If that doesn't work, it sounds like there is a zoom feature and it is set to copy at 110%, making it too big to fit on the A4 paper and it is continuing on Page 2.
Jul 29, 2017 | Canon NP 6050 Copier
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
Toshiba e233 photocopier does not coincide with the top margin of the original copy
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Nov 30, 2012 | Office Equipment & Supplies
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Canon MX850 printer - ADF copy has black line on it
Hello, my name is Steve,.
This is a common problem and an easy fix.
If you lift the ADF / top cover assembly up, you will see a small narrow piece of glass next to the flat-bed glass.
Ths is called a "Slit-glass". The only purpose is to read content from that point by the scanner, The Scanner will sit in the underside of it.
It is dirty. Wipe this with glass cleaner and a soft lint-free cloth. you may need to do this several times. Concentrate the part of the glass were this image problem is just by the orientation of the document you are installing with the direction of the document you are passing through the ADF.
It will take several attempts, but with each try, make a new test from the original document, unyil the problem disappears.
I believe this will solve your problem, Best , Steve
Mar 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
Vertical Line on scan and copy
I would like you to exactly follow the steps in order for you to resolve your issue.
JUST DOUBLE CLICK HERE ==>> DOCUMENT
Please update me regarding the result.
Thank you so much.
adonscott
Jun 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Sharp AR-651 Laser Printer Logo
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
