Question about Maclaren Techno XT Standard Stroller
I'm having trouble adjust the lap straps for my growing son. It's now getting very tight around his lap, especially now that he's wearing a winter coat. It shouldn't be this difficult to adjust. Thanks in advance.
    Guru:
  • 541 Answers
Try this
http://shop.maclarenbaby.com/downloads/instructions/Techno_xt%20ins_leaflet%20US.pdf
Posted on Nov 08, 2010
Maxi Cosi Pria 70 ****** strap too tight
Make sure your son does not exceed the weight limits for the forward facing harness. Do not put your child in the harness wearing bulky clothing, but use a blanket or poncho in the car instead of a snowsuit or winter coat.
Jan 03, 2014 | Maxi-Cosi Baby Gear
How do you wear the parents of invention ultimate ring sling?
Adjust the wide panels over both your shoulders and lower back to ensure that you are comfortable and that your child is carried safely,then bring the thinner straps around just over your chest through the loops/rings and pull tight as if tightening a belt around your waist. be sure the straps are secure and it should hold tightly with no give.
Aug 01, 2010 | Parents of Invention Ring Sling Baby...
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
Shoulder straps will not extend
In between were her legs are there is a cocso sign push down on the button and pull the strap tight. A black strap should be handing out from under the button.
Jan 04, 2009 | Cosco Alpha Omega Elite - Hammer Print
Britax Roundabout car seat thigh strap adjustments
Carseats werent made for all the extra stuff we have to put on our kids. So will have to take your little one in and out of the snow siut in the car. I have an auto start button on my keys so I can warm the car before we go out there, so I can take my little one out of his warm wear in the car. Its just a headache putting them back in it once you get to your destination.
Nov 28, 2008 | Britax Eclipse Si - Paris Convertible Car...
Rear facing latch problem
I had trouble getting mine tight too and my sister said what she did was kneel in the seat and then pull up on the strap. I tried that and it worked! I think it pushes the seat down more so that you have more strap to pull.
Sep 16, 2008 | Eddie Bauer 3-In-1 with Latch
Harness straps
well all u doo is u should look on the see or manual and read or go online to see the manual
Aug 08, 2008 | Evenflo Embrace
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Maclaren Techno XT Standard Stroller Logo
553 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
