Question about Bosch Office Equipment & Supplies
My Zebra LP2824 Plus skips every other label. This happens no matter how many labels it is told to print (1-whatever). It does not happen when printing test labels, only when printing from Liquor POS 5.1
Flashing red for zebra lp2824plus
Posted on May 16, 2011
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
My zebra LP2824 Thermal printer is driving me nutty. It skips tags between each printed one. I'm printing on thermal labels that are 1.1875x3.375 (2 side by side) so the total measurements are 2.375x3.375....
possible is not the best printer to work on site-by site labels because the sensors that read the gab are on the midle of the label and possible can't check wen the label start and end. try the printer S4M (sensors on lenf side), or try normal labels and press the botton until flash 2 times and release the botton (calibrate).
Dec 14, 2008 | Zebra TLP 2824 Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
758 people viewed this question
Top Bosch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Bosch Office Equipment and Supply Expert? Answer questions, earn points and help others
