Question about Samsung SPH-M500 Cellular Phone
Memory Card Not Present
I put the memory card in, followed thru the steps and get the above message. turned off & on phone, still says memory card not present.
  • mle1 Jun 18, 2008
    I have exactly the same problem. Turn the phone on and off, but not luck either.
5 Suggested Answers
SOURCE: Samsung D600 memory card format
When i insert memory card it says not allowed
Posted on Dec 15, 2008
270rexton
  • 762 Answers
SOURCE: I am trying to program the memory card for my LG 9100 Keybo
Hi,do you have card reader? if so use your pc to format the card,use FAT32 format. If your PC doesn't recognise the card then it is broken.
Ratre me if helped,thanx.
Posted on May 01, 2009
SOURCE: Samsung Guru 1410 Memory problem
Goto Applications-->Bluetooth-->Default storage and change to memory card. Thats all
Posted on Jun 10, 2009
eagle338
  • 4889 Answers
SOURCE: msdc not present
MSDC error indicates a file system related error. More often than not it is caused by corrupted file system on the memory card. However it can also occur due to faulty in built memory. To find out which one it is remove the memory card and see if the problem persists and let me know your observation(s).
Sai.
Posted on Mar 08, 2010
SOURCE: cannot access to my memory card files???
try to format the memory card or scan it with the kaspersky 2010
Posted on May 30, 2010
Testimonial: "fixed"
Nokia 2690 no show memory card problem solution
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
Nov 12, 2012 | Cell Phones
NOKIA 2690 NO SHOW MEMORY CARD
Nov 12, 2012 | Nokia 2690 Cell Phone
I forgot my memory card password.i want to unlock it.my phone model is Nokia 2700Classic.plz help me.
Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
  1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer,
  2. After finished downloading, install it to your mobile phone.
  3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  4. Run FExplorer and open the following location C:\system.
  5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
  6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  7. When you finished the above steps, you will find the password of that file.
Feb 15, 2011 | Cell Phones
Hi. How am I going to transfer the memory in use of my messages to my 4GB memory card? Please reply
Do follow this steps to change the memory in use from phone memory to Memory Card.
Menu > Messages > Options > Settings > Others > Memory in Use > Select your Memory Card from there.
Hope it helps.
Dec 30, 2010 | Nokia C3 Cell Phone
Phone Nokia 2700 Classic remove password micro sd 1Gb memory Card
Hi ,
Follow the following steps to remove the password check in
memory card
It has worked for the following user . pls click here to view
For any quires write back to me .If yo are satisfied with my answer please vote for me(4ups) . thanks in advance
Nov 27, 2010 | Nokia 2730 Cell Phone
My memory card is locked how to open it?
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
Jun 05, 2010 | Nokia 6233 Cellular Phone
Forget my memory card pasword
Jun 05, 2010 | Nokia 6300 Cellular Phone
I cannot unlock my block memory card 4 5130 xpress music
Rate me if this is helpful. Good Luck :)
Jun 02, 2010 | Nokia 5130 Cellular Phone
Transfer files into memory card
Please follow the below steps:
Open Messaging -> Options -> Settings -> Others -> Memory In Use.
Then change memory in use to memory card and files that you received will be save in the memory card
May 29, 2009 | Nokia 3230
Password recovery
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Nov 27, 2008 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Samsung SPH-M500 Cellular Phone Logo
154 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
