Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Dead Upright Frigidaire Freezer
I have a 5 year old Frigidaire freezer FFU14FC4CW1 that worked fine until this week. It started getting warmer inside so I unplugged it 48 hours in case it was frozen. After reconnecting it it stays warm. The circulator fan stays on constantly but the compressor doesn't come on with its normal hum. I can feel it get warm and it does slightly vibrate to the touch but nothing like it is supposed to. The temp switch seems to work because it shuts the fan off when I lower the setting. I cannot locate any coils to clean anywhere. None are visable either below the unit or mounted on the cabinet. Any help is appreciated.
  • notsmiling Aug 19, 2008
    I had the same problem 3/28/08 . The repairman stated it was the relay switch and replaced it. Today-08/18/08- the same problem again. I had to throw out alot of the food. I am ready to throw the freezer out. I purchased 5 new appliances in 8/3/03, all frigidaire products. I have kept the extended warranties- but each time they stated- I was not using the product correctly. The stove- would not keep the temperature, I had a gas stove and one of the grates cracked or split in parts. This was on the small burner. The interior of the oven bottom had a huge spot where the paint or what ever was flaking off. I replaced this with whirlpool. The dryer did not keep the temperature and cut off or would not complete the cycles- replaced with whirlpool.
    Genius:
  • 1,122 Answers
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Posted on Jun 16, 2008
My freezer high temp light is on and it isnt running It is 2 years old and it is a Frigidaire Upright Freezer with digital temp on the outside of the freezer. My son went out to the garage 8 hours ago and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 14, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Moisture forming on inside of freezer
is there anything that's preventing the door from fully closing( too fully)? the door gasket might be the culprit (problem).
May 04, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer has difficulty shutting off
Check the relay located on the compressor on the back of the unit. Sounds like the relay is not completely shutting down the compressor. Almost like it is still allowing electrical currents to get to the compressor
Feb 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Warranty and product service
you should def have a 5 year warr on your compressor( all your sealed system parts) , youll need a factory authorized company, to come ck out so if it is a sealed system repair they will honor y our warr. dont know how it works where you are but,theres got to be 12 companies just in my area willing to do that
Oct 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
431 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
