Question about Sony PlayStation Portable (PSP) Console
Cannot access to network utility disc - Sony PlayStation Portable (PSP) Console
  • 122 Answers
I thin u hav some network problem or u may hav som spam i it ...u vsit this website to solve this prolem click hear
Posted on Nov 08, 2010
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
Tip
Details of your Router Or Network
This Utility program from HP will help you locate few details on your network
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click on the link to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPSDR.EXE )
Follow the Instructions on the Screen and do accordingly. http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e013-1&h_keyword=dg-NDU
on Jun 30, 2010 | Computers & Internet
I have ASUS WL-167G v3 Wireless USB Adapter. It works well with my MacBook but when I connect it to my WinXP PC, it detects the two networks that I have in my house, but does not connect to neither. Both...
You mentioned that you have Windows XP SP1... You need to install at least SP2 or even SP3 for this adapter to work. If this computer doesn't have internet access at all, then you can usually get SP2 or SP3 on a disc for free from Microsoft.
Feb 28, 2011 | ASUS Computers & Internet
Need the pin number
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Hope this is helpful.
* Dont forget to rate this solution and write comment
Nov 12, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
The dsl modem the i have did not come with an access code .. how do i find it
Nov 06, 2010 | Arris Netopia 2210 ADSL2+ Modem SinglePort...
Access server manager 3.6
The DECserver 732 is a high-density, high-performance asynchronous device and remote access server that provides 32 MJ8 (RJ45) serial ports. The DECserver 732's serial ports support either of two sets of software-selectable four-signal modem control signals. The DECserver 732 has AUI and 10BaseT Ethernet connectors. The DECserver 700-16 supports up to eight sessions per port and speeds up to 115.2 Kb/s per port. The DECserver 732 has an external FLASH socket for the customer-installable flashcard. When installed, the flashcard allows self-booting operation. The DECserver 732 runs DECserver Network Access Software (DNAS), which delivers multi-protocol support for TCP/IP, IPX, and AppleTalk networks. DECserver 700 units are designed for tabletop or rackmount configuration
the u need to check these site for more info:
http://www.vnetek.com/s-137-digital-networks.aspx
Jan 05, 2010 | Digital Products Digital DECserver 732...
Cannot connect to access point
Are you using the Linksys utility to connect to the wireless network?
If you are using that then you can switch over to windows utility.
It is very simple to connect to the wireless network.
Click Here for More info
Oct 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
One computer on network can't open internet pages
Try resetting the modem. It may be the Modem has to re-assign an appropriate ip address to your desktop.
Apr 01, 2008 | Computers & Internet
No association with access point
hi
is the access point WEP enabled? or is it public? as long as you are able to detect the access point, try and edit your profile to which you can connect.
if it is a WEP enabled access point, you should have a passphrase key to access it.
if its public...
try and use this...
http://www.makayama.com/EasyWifiRadar.zip
hope this helps
Jan 28, 2008 | Linksys PCMCIA Network Card PCMPC100...
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
