Question about Whirlpool Calypso GVW9959K Top Load Washer
No power I just bought the washer on my first load it washed for a few min the kicked the braker on my main. the problem is y lid locked and i cant get ot open cause i have no power on my washer (the outlit does work) Help good cloths are in ther and it will be 5 day for a service man to come. i dont want my stuff o milldo.....
  • 246 Answers
You have this listed under a Calypso washer heading. The Calypso's don't have a latch mechanisim on the lid. To you have an Oasis or Cabrio? Those are top load washers by the some of same manufactures that do latch. If so, you would have to push the two green clips between the front panel and the top of the unit towards rthe back while lifting up on the top. You can get your clothes out that way if it is one of these models.
Posted on Jun 16, 2008
Samsung WF42H5400 AW/A2 Washer was briefly unplugged, then plugged back in. Now, it will not power on. Any ideas as to why?
hi Peggy.
Main reasons a washer will not start (either front or top load):
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board faulty or shorted.
Power to Washer
Be sure the washer is plugged into the electrical outlet in the wall. Also be sure the breaker switch in the breaker box is turned on. If you live in an older home your box may be called a fuse box. If so, make sure the fuse is in good working condition.
Door Switch Strike (Front Load Washer)
The door switch is a safety feature on front loading washing machines. On front loaders, the door switch must be closed and the door must be locked. If this switch malfunctions, the washer won't start. This switch is in the door frame of the washing machine where the door shuts. If you suspect the door switch is causing your washer to not start, carefully check the strike where it engages into the door lock assembly. Be sure the lock is working properly by keeping the door shut and locked shut. You can check the door switch for continuity with a multimeter. Be sure to disconnect the power to the washer when you check for continuity. If there is no continuity, replace the door switch.
Lid Switch (Top Load Washer)
A lid switch is a safety device located under the lid on top load washers. This lid switch will not let the motor operate when the the lid is open. If the lid switch is faulty, then the washing machine will not start. It may fill with water but will not spin if the switch is faulty. Some lid switches on top loaders also control the water inlet valve. In some top load washers, if the lid switch is bad, the washer will not fill with water. The lid switch is under the lid. There is a pin or pusher attached to the lid. This pin or pusher (when lid is closed) will press the lid switch. If your washer will not start, be sure the switch is being pressed. If the lid switch is being pressed but no power is being supplied to the washers motor, then the switch is most likely bad. To test the switch, turn off power to washer and remove the wires from the lid switch. Check the switch for continuity with a multimeter. If there is no continuity, replace the lid switch.
Start Switch and Timer (Top Load Washer)
The start switch timer on top load washers is part of the timer. This starting switch is turned on by pulling out the timer knob. If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from the washing machine and find the timer contacts. Some top loaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel. You can also test this switch for continuity with a multimeter while pushing the button in. Remove power from the washer before testing for continuity. If there is no continuity, replace the start switch and or timer.
Timer Knobs
Sometimes the timer knob wears out and cannot properly engage the timer shaft. If this is the case, then the knob is at fault. The knob cannot grip the shaft therefore is unable to turn the machine on. A worn knob will cause it to slip. Turn off power to the washer and inspect the back of the timer. Make sure the timer shaft engages the knob when it is pulled in or pushed out. If the knob is worn, replace it with a new one.
Drive Motor
Both top and front load washers use a motor that spins and agitates. (A top load washer uses a reversing motor) The motor spins in one direction to agitate and the other direction to spin. When the wash motor will not turn on it may be faulty. If the motor makes strange humming sounds then the motor may be at fault. To test the motor, remove the belts and try to start the motor. If it runs then you know something else in the washer is causing the issue. On newer direct drive washers, you will have to disconnect the pump and the coupling to the trans. If the direct drive motor turns on, then then you have a transmission issue or possibly the pump. If the direct drive motor won't start then it should be replaced. On front load washers the motor drives the washing basket with a ribbed belt. Remove the belt and try to start the motor. If the motor runs, then be sure the basket turns and doesn't have anything stuck or jammed between it and the outer tub basket.
Main Electric Control Board
The control board controls every component in your washer. If the main control board does not properly control the motor, the filling valve, the drain motor, or the door lock, the washer will not start. The only way to determine if the control board is at fault is to visually inspect it. Check for burned areas or any component on the board that may look burned or damaged. If you find burned areas or components on the control board, remove and replace it.
or read up more at this link.
samsung washing machine will not turn on Google Search
Dec 12, 2017 | Samsung Washing Machines
My washer is on control lock what do i do
I would kick off the breaker and kick it back on. Wait a few mins and see if the lock disengaged
Oct 29, 2013 | Kenmore 4292x Front Load Washer
Error code f5e4
Condition: Lid not opened between loads
Check/Repair: The main electronic control board doesn't detect the lid opening between loads. Unplug the washer and check the wiring connections between the lid lock/switch and the main electronic control board. If the wiring connections are okay, replace the lid lock/switch.
Jun 08, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
Aug 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to reset the system
Hiya,
in most cases of a none responcive machine after intalation many people forget to turn the water tapes back on after conecting the machine this will stop it in its tracks so i would surgest double checking you have returned the water connectors to the on posistion, unpluging the machine for a few mins should reset the programme.
Hope this helps
Apr 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing a comforter and machine stalls. Code says Door is open..it isn't and will not let me open it. What now?
The only Reset is unplugging waiting a few mins and plug it back in. If not perhaps the lid locks have failed.
Jan 20, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore HE 9t quiet pak
Sounds to me like the Main Computer has failed. F11 means it is not communicating with the Motor control Board. It has nothing to do with the door locks. Remove to lid of the machine to axcess Main control. Sometimes a tap or two on the board makes them work again for a short time. Leave unit powered down for a few mins to reset board.
Nov 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LG washing machine
the Play/Pause button? Check if you have Child Lock on? (Hold the Pre Wash button for three seconds to turn it on or off.
Feb 04, 2007 | LG WM-2277HW Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
