Question about Whirlpool Duet Sport HT WFW8400TE Washer
Brand new machine and it doesn;t even wash or spin...did all the installations correctly!
  • 478 Answers
Check to make sure the water is turned on. It is often something simple in this situation.
Posted on Nov 08, 2010
Why does my new Frigidaire washer do 6 wash-cycles (washes for approximately 4 minutes out of a 50 minute planned wash) then spins and drains?
Who installed the machine? If it is a front loader did you remove the shipping bolts? If it is installed correctly I'd say it has a bad control board.
Unplug the machine, let it set for one hour and then try it again.
Oct 22, 2014 | Frigidaire Washing Machines
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Our new integrated washing machine (Baumatic btwm4) sometimes doesn't spin properly and clothes are very wet. Even thought a single spin is selected, the same poor result. The machine is definitel
1) tes the belt for broken or worn replace
2)test the door switch, this cause to NOT spindle the machine , replace if necessary or readjust
3)Main control module or CCU, if the door switch test o.k, tight any wires connector well from loose, otherwise the CCU is faulty.
4) motor control module, this receive signal from CCU, tight any wires connector for loose, otherwise you must replace the board faulty.
Jul 18, 2012 | Washing Machines
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
It spins, but doesn't pump
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
It doesn't spin or pump
frozen pulley pump replace
It pumps, but the water returns
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
My Defy 600 does not drain all the water out and wont s apin. When I try to start a new cycle it wont let any water in, i suspect thats cause there is still water in the drum. Help!!!!!
hello there and welcome to fixya
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Aug 23, 2011 | Washing Machines
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
My clothes are soaked after being washed. My washing machine is brand new. It all seems to be hooked up correctly. The tub spins but seems like it may be stopping and not spinning after a minute. What...
Try redistributing the clothes, it sounds like it thinks it is out of balance so won't spin. Also make sure it is installed level and not rocking.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 16, 2011 | Amana NTW5400TQ Top Load Washer
My Servis M6725 washing machine gradually fills with water even when it is switched off. We have tried changing the inlet valve but it still happens.
this is very comon review
decided to buy a Service M6725 machine. I bought one from Argos 'express delivery'. Installed it in a matter of minutes and did a cleaning wash. From then on the machine refused to work. Argos kindly replaced the machine (with the same model) and all seemed fine for a couple of weeks and then for no apparent reason the spin cycle would not perform. Yesterday a Service engineer arrived to 'sort' out the problem. He told me that the no spin was because of an unbalanced load and the machine was working correctly and left me to try more washing. Same result. House full of dripping washing and an angry wife. I am replacing the machine with another brand. ...
Apr 28, 2010 | Washing Machines
Washing machine wont go from wash to the spin etc automatically
Do not fool with this you will void the warranty, you have a defective machine, contact the manufacturer.
Apr 17, 2017 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet Sport HT WFW8400TE Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
