Question about Samsung 943NW Monitor
Monitor flashes at the bigining at the start up and turns OFF. Music plays as usual but without pic. When the monitor is switched off and on from the bottom touch control panel, monitor flashes again with the desktop screen and goes off. When this is done for 30 or 40 times the screen reappear and continue to function normal. But at the restart the same problem appears.
  • 11,361 Answers
It has dying power supply due to bad cpas, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 08, 2010
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
When my computer shuts down, the Monitor flashing green light keeps flashing. My problem is that I can not turn the Monitor "on" light off.
its a default feature. playing with the fromt pannel may cause an early filure or malfunction.
to get if off, switch off it from the power source. or remove the power cable from back.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
The monitor won't go on after holding the power button
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 15, 2010 | Neovo F-417 17" LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Samsung Syncmaster 204T flashing
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Jun 21, 2009 | Samsung 204T 20" LCD Monitor
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Screen flashes "on" and then goes black on start up...
This is usually a bad capacitor problem. They would need to be replaced, or get a new monitor. Some shops will work on them, but you have to weigh the cost vs buying a new monitor for almost the same price.
There are some websites on repairing your own, but you need to know a bit about soldering and such.
Mar 28, 2009 | ViewSonic VA912 19" Flat Panel LCD Monitor
MONITOR HP L 1940 TFT
I jammed my auto button and the screen now stays on!
Jul 25, 2008 | HP L1940T 19" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Open Questions:
Hi! I have a problem with my Samsung 943NW Monitor. Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor d Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor driver just vanished, and I had a noname plug and play display and the 1440x900 resolution just vanished and was 1024x768 instead. When I tried to install the correct driver (which windows says I've sucessfully done) nothing has changed. I'm using Windows 7 64 bit, which was the only change in the late months around my com, so this MUST be related some way. When I tried to install the driver from the disc I have given along with the monitor itself, the installer says I need to visit samsung's website for 64bit and Vista drivers. No downloaded drivers worked either. Then, after hours of searching I just watching my messed up screen, then suddenly windows did something I still couldn't figure out, and everything was fine again! I had 1440x900 resolution and everything went well... until today... This all happened a few weeks ago, and now I had to move my come in my room from one point to the other, so I plugged everything off, moved it, plugged back in, and now I have the same issue, but still without a solution. If you need any other specifics just ask, and thank you for your help in advance! P.S.: In sort, the windows 7 64bit is messing with the monitor driver after I plugged in the jack thingie, but removing it isn't solving the problem at all.
Mar 01, 2017 | Samsung 943NW Monitor
Hi! I have a problem with my Samsung 943NW Monitor. Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor driver just vanished, and I had a noname plug and play display and the 1440x900 resolution just vanished and was 1024x768 instead. When I tried to install the correct driver (which windows says I've sucessfully done) nothing has changed. I'm using Windows 7 64 bit, which was the only change in the late months around my com, so this MUST be related some way. When I tried to install the driver from the disc I have given along with the monitor itself, the installer says I need to visit samsung's website for 64bit and Vista drivers. No downloaded drivers worked either. Then, after hours of searching I just watching my messed up screen, then suddenly windows did something I still couldn't figure out, and everything was fine again! I had 1440x900 resolution and everything went well... until today... This all happened a few weeks ago, and now I had to move my come in my room from one point to the other, so I plugged everything off, moved it, plugged back in, and now I have the same issue, but still without a solution. If you need any other specifics just ask, and thank you for your help in advance! P.S.: In sort, the windows 7 64bit is messing with the monitor driver after I plugged in the jack thingie, but removing it isn't solving the problem at all.
Samsung 943NW Monitor Logo
190 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
