Question about GE GSS22JFMWW Side by Side Refrigerator
Water is leaking slowly from the bottom of the freezer door of my GE GSS22JFMCWW side by side refrigerator.
  • 1314 Answers
SOURCE: GE side by side refrigerator gss22jfmcww not cooling
they are talking about the motherboard at the back of the unit and are prob right parts people see the promb a lot and was just trying to save you some cash good parts store pull the fridge out you will see a panel at the back on the freezer side pull the cover and inspect and you will see a board look for a burned resistor ge has corrected the problem and the new board cures the problem just follow the inst instructions
Posted on Jan 01, 2008
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
How do I clear the frozen drain in the bottom of freezer?
Posted on Apr 06, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
  • 44 Answers
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Posted on Jun 10, 2009
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from bottom
Hi, during the defrost cycle the water runs down a pipe to a pan by the compresser where it evaporates back in the house. Ck to see if water is prevented from reaching this pan
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Freezer that ice if forming in the bottom of the freezer
drain in bottom rear of freezer is stopped up deice and use turkey baster to force hot water through drain
Jun 24, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Water leaking from freezer door.
Yeay!!! Thank you soooo much!! I opened my freezer door for about 5 minutes and also turned the freezer temp warmer, and my water dispenser worked again. And thanks to you guys, i didn't need my husband's help figuring this out :-)
Feb 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gss22jfmcww side by side refrigerator warm
yeah if the fan does not work when you press the light switch thats the cause for the temperature proble, because the low temperature is not circulating stays just in one palce and yes you can replace just the fan get the manual from GE to see how to do it
Dec 30, 2007 | Refrigerators
GE GSS22JFMWW Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
