Question about Miele Dishwashers
I have a miele g2220 sci dishwasher. keeps stopping during cycle and displays fault code F14 which is not in the manual. please help.
  • Anonymous Mar 13, 2014
    My dishwasher mieleG898 sci plus is displaying. ------- like a dash line .I av unplugged it and it still displays same lines when plug back in
  • 725 Answers
The clogged circulation pump (error code F14)
Posted on Jun 16, 2008
F14 fault. What do I do?
Miele Fault Codes
Different brand dishwashers have different fault codes. That said, this may well be your brand. It does list the F14 fault code as well as the others.
Jun 03, 2017 | Dishwashers
F14 fault Flashing. 4 Month old dishwasher. What do I do?
Well first of all, before anyone can help you, you should post the make and model of your dishwasher.
Miele G2220 sci ( no code showing) bottom arm not spinning not sure if it's spraying water though, any thoughts
Try running vinegar through the cycle hard water will keep water from getting through. Just try;
Jul 11, 2014 | Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
What does it mean when F 14 is displayed in the window?
F14 - "level/pressure switch failure." The level switch monitors the dishwasher's water pressure, as it circulates, which is especially critical, during the heating cycle (main wash). Level switch failure can commonly happen from poor circulation, or from the defective level switch, itself. The most common reason for poor circulation is low water fill level. In other words, during the water intake cycle, insufficient water came into the dishwasher. Observe if enough water did come into the dishwasher, Check the water level, by using the filter's handle (located on the floor, of the inside of the dishwasher) as a reference point. At the end of the water fill stage, the water level should be just underneath the filter's handle. If the water level is more than half an inch, below the filter's handle... then that could be a problem. The sympton would be a noisy, sluggish, whooshing sound of water, during circulation - It wouldn't be the same old quiet Miele dishwasher you knew.
If you have the low water fill problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
Other causes for F14, can be weak circulation from foreign item(s) (plastic wrapping, broken glass, etc,...) lodged inside circulation pump impeller, or no circulation, at all (circulation pump stuck). Of couse, the defective level switch, itself, can cause the F14, too. The least common causes for the F14 can be broken wires to and from, level switch and electronic unit, and a defective electronic unit.
Oct 18, 2010 | Miele Premier-Plus Built-in Dishwasher
Keeps stopping and bringing up the fault F14, we have reset but it continues. Please help as just about to start the Sunday roast for 7 and don't want to wash up!!
You don't say which model you have (and there are a lot!).
If you do not have any instructions then you can get them from their web site.
If you go to http://www.miele.co.uk/customer/OperatingInstructions.aspx , you will find a list of instructions.
Choose the one for your machine and look at the Trouble Shooting section.
Sep 19, 2010 | Miele Dishwashers
F14 is presenting after completing 75% of cycle, then the machine stops, this happens on all cycles
Hi dear.Please follow this if you can do it,other wise call service department.I hope that solves your problem.Thanks. F14
Water intake fault: Heater pressure switch
Cause:
Heater pressure switch B1/13 defective.
Remedy:
1. Check the heater pressure switch.
2. Check the connection plug and wiring harness.
3. Replace the heater pressure switch, if necessary.
Cause:
Circulation pump inoperative. Circulation pressure too low (no pressure at
heater pressure switch). Pump may be blocked by foreign objects.
Remedy:
1. Check the circulation pump for foreign objects.
2. Check the circulation pump capacitor.
Aug 18, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
1,926 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
