Question about Sharp LC52D65U 52 in. LCD TV
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
  • Sharp Master
  • 8,457 Answers
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Posted on Nov 08, 2010
My sharp aquos LC-60E79U has no picture. Perhaps I have a backlight problem?
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 13, 2016 | SHARP ELECTRONICS DE AQUOS LC-60E79U 60"...
I have a Sharp Aquos LC-46LE830U. The white link blinks and there is no picture or sound. I did the reset. It turns solid and picture comes back, but goes out almost immediately.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Apr 02, 2016 | Sharp LC46LE830U - LC 46LE830U - 46 Aquos...
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a sharp LC-37D40U that will not power on. The power light blinks 1 time every second. I held the input and volume - button while plugging the TV on and the TV cuts on and then cuts right back off,...
OK if you have blinking red light.
Try to open the cover then disconnect the inverter board after that try to power it on again..
If the light stays in blue (LIT) and of course you don't have picture or backlight you have faulty inverter board that need to be replace.
Nov 08, 2012 | Sharp AQUOS LC-37D40U BACKLIGHT INVERTER...
Green blinking light tried the reset unplugging pressing the wolume up and channel down button solution TV turn on after 20 seconds went black only audio working and then turned right back off
U have sound but no picture?Ur lcd inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 11, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only...
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
May 06, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
May 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Lc-46d64u
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, youd have to call Sharp to locate a local service center.
Mar 23, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp aquos lc42d62u green blinking light
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC52D65U 52 in. LCD TV Logo
353 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
