Question about Dell UltraSharp 1907FP 19" LCD Monitor
Open the LCD cover
How to open this DELL LCD cover? Thanks-Minh
I had the same problem and it was quite difficult to open the case. So now I want to share my experience on how to open it and also publish some helpfull pictures (of course these also works for the 2007 screen):
1. I made a tool from the top of a aluminium can. It's quite thin and bendable but still strong enough (make sure there are no sharp edges).
2. You have to understand how the parts of case are joined together and hold by snaps. Here a piture of a snap. The front frame has bails(?) hitching on the snaps (see picture 3).
Move the tool between the bails and the snaps so they will let go. The first snap is always difficult. Start at the top or bottom, because the sides have a "double" wall (see picture 1 black and grey) and it is difficult to find the right way.
Open the LCD cover - db1d653.jpghttp://i.fixya.net/uploads/images/db1d653.jpg" alt="db1d653.jpg" class="h_mi" />
There are five snaps on each side. Always one in the middle, one on each corner and one between. Start with the middle one. Use a screwdriver to get a little gap between the two parts of the case. Push the tool inside til the snap will let go and the case opens a little. Continue with Open the LCD cover - 2d8a490.jpgap.
When the case is open be carefull there are sameOpen the LCD cover - e6022ef.jpgdered to the front part.
If you have a problem with the power button. Usually there is a thin bolt missing like the other buttons have. I glued a very small screw into the button. One like used to fix the sOpen the LCD cover - 7b0edf4.jpgt board. Make sure the length is appropriate.
Hope this helps anybody.
Clibo
Posted on May 01, 2009
  • clibo967 May 03, 2009
    FORGET MY LAST SENTENSE. The electrical push button is NOT directly behind the button on the front. It's behind the small white arm you can see on the last picture (at the left border of the button). This arm is too week and sometimes broken. Unfortunately this is a design fault by Dell. I drilled a small hole through the front and use something thin like a paper clip or keep the monitor switched on and use a switchable multipoint connector.
  • 46 Answers
Check out the help videos at this link
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
  • 87 Answers
Take out all screws and use a flat object to pry it open... their glued together
Posted on Jun 16, 2008
Power switch
Please look through my pictures here, some time you crack it open at the bottom edge first, or from the top bezel, look for slot if it has them. Just be realcareful, do not separate the bezel too far from the chassis since the cable is really short and delicate.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 18, 2010 | Dell E207WFP LCD Monitor
How to open the flat screen
Francois, If you really want to remove the pedestal and then rear plastic cover from the front BEZEL, then why don't you visit YOUTUBE and view some video clips of "LCD monitor disassembly" and "LCD monitor repair" to see how to "PART" the cover from the bezel!!! There sure is a lot of stuff to see on YOUTUBE. HINT!!! YOU must protect the LCD PANEL at all times!!! GOOD LUCK, 12fixlouie
Dec 11, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Open the back door
remove all screws at the back. and unlock all snap lock at the back cover.
May 30, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell Flat Screen Model 1907 FPt
Appears you have an inverter problem. Do you hear any sparking?
Mar 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dog Hair under protective coating on monitor
get your Dell manual out and look in the index for lcd cover. It should tell you how to take it off and maintain it. If things get behind it it should be removable. Also www.dell.com is very informative with their support group.
Sep 13, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
579 people viewed this question
Alun Cox
