Question about Home
Just bought a new toilet and installed it in my bathroom and after everything was installed to the t i turned the water supply on and nothing filled the bowl or tank ???? what could be causing this ?
    Genius:
  • 1,015 Answers
It is possible that there could be a packingbrace holding fill valve shut if so remove it.On som types of fill valves that have a float ball on a rod attached to fill valve.Usually on the top of the fill valve there will be a screw that adjusts height of float ball.If float is adjusted to high it will not let water in.Turn screw counter clocwise and see if it lowers rod and float ball.You should see water start running into bottom of tank.If this works you can adjust screw until you get a reasonable fill time about 45-60 secondswould be good.Hope this helps. Thanks.
Posted on Nov 08, 2010
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
Eljer toilet bolts rusted causing massive flooding
Turn off the water at the supply (under the toilet, usually).Flush the tank to remove all water from the tank.Disconnect the supply from the tank.Remove bolt caps or bolt covers from where the toilet bolts to the bathroom floor.Remove bolts from the floor flange. When you lift the toilet up, you'll see a metal or plastic flange. If the toilet has been there for a long time the bolts may not pull out of the flange easily. In this case you may have to use a small hacksaw to cut the bolt below the nut.Put newspaper or an old towel on the floor so you can place the old toilet on it. Lift the toilet off the flange.Take the new bowl (assuming this is a two-piece toilet) and turn it upside down. Position the wax ring on the horn of the outlet. Install new solid brass flange bolts, mount them and position them on the centerline on either side of the outlet.Push the bowl down over the bolts and seal the outlet. The wax will squeeze down and seal.Put the new bolts, washers and bolt caps on. You may have to trim the bolt with a hacksaw.Once the bolts are secure, mount the tank.Make sure the gasket between the tank and toilet is in place. Then position the tank on the bowl. Run bolts through the tank and secure. Don't over tighten (the tank can crack).Hook up the water supply line.Connect the supply to the line on the bottom of the tank.Turn on the water.Let the tank fill.Flush once or twice to make sure the water control is properly adjusted.Put the tank lid on.Enjoy.
ford performance chip.
May 25, 2012 | Eljer Home
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
The little hose that attaches to and pours water into the long vertical tube (to fill the tank) has slipped off twice and sends water over the side of the tank and floods my bathroom floor. The little...
to get a new one would require a new fill valve for your toilet, or a local plumber might have one rolling around on his truck.
try a paper clip, one thats a little bigger than the tube. slide it onto the tube, then clip it onto the fill tube like you would a piece of paper, this works in most cases.
Aug 17, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Aug 05, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Toilet water valve does not fill water in the tank
Went to Lows and got a new fluid master water valve. Before I got any advice it's done.
Jan 13, 2010 | American Standard Cadet 3 Right Height...
Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Feb 01, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Dec 21, 2008 | American Standard Cadet 3 Right Height...
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
Home Logo
61 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
