Question about Brother MFC-465CN InkJet Printer
I have installed the printer but cannot print my word document. What should be selected on the printer? I dont know what to select on printer. HELP!
  • 1,218 Answers
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Posted on Nov 08, 2010
I dont know how to prtint
here are some steps to print document.(just make it sure that your printer is properly installed in your computer.including the printer driver.
1. 1
Open a program that allows you to insert text into a document or get on the internet.
2.
If you were to open a program, you would need to type text into the document. If you were to get on the internet, you could skip to step 7.3.
After you have typed text into the document, you need to locate the menu bar, click on file, then point to print.4.
Click on print.5.
When the print dialog box appears, select the printer you want to use (if it is not already selected) and select the number of copies to print.6.
Click OK.
7.
If you were to print a page or pages from the internet, follow steps 3, 4, 5, and 6, except you don't have to type text into a document to print.
Sep 23, 2011 | Office Equipment & Supplies
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
I DONT INSTAL MY PRINTER LASERJET HP 1522N IN WINDOWS 7 64 BITS
go to
http://welcome.hp.com/country/us/en/support.html
select "Download drivers and software (and firmware)"
type in "LASERJET HP 1522N" without " "s and press enter
then select windows 7 64bit
Sep 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
My printer prints very small laters
>what applications or documents are you printing?
>this could be application specific or the printer driver is incompatible with the application. you can check by printing other application or documents.
>you can also install generic driver, go to printer and faxes folder add a printer, add a local printer and select usb port, select hp as manufacturer and select deskjet 990c as your print driver
>you can also try to go to www.hp.com select support and drivers and then download the latest driver for this printer and install it
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
Can't print without black Ink
From HP's website:
The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges.
Try this::
Leave the empty cartidge in and go to print, select the printer, click on preferences, then the paper/Quality tab. there select color and best. This way you wil be able to print your document.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | HP Photosmart C6280 Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
I HAVE SOMEHOW WHEN TRYING TO TO PRINT HAVE BUILT UP IN THE STORED DOCUMENTS ABOUT 100 DOCUMENTS AND DON,T KNOW HOW TO CLEAR THEM AND SO CAN,T PRINT ANYTHING ELSE CAN YOU HELP PLEASE
put the printer off for some minutes ,remove the printer interface wire from the cpu,now go to start on your desktop & select setting ,then printer &faxes .rightclick that printer icon &select cancle all documents. by now ur pilled up documents must have clear if it remains and prove abortive, restart the cpu & go thru this procedures again it will clear the whole documents. then reconets your printer &put it on,put paper & allow it to get read on its own. then rightclick &select properties select print test page.by now you should get testprint page & your printer is again ready for use.
thanks u can let know your result for further assistance.
Oct 05, 2008 | Lexmark Office Equipment & Supplies
Printing from wrong tray
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Jan 24, 2008 | Office Equipment & Supplies
Trouble with color printing
Have you tried to print a 'test page?'...
Go to 'Printers and Faxes'. Select right click on your printer and select 'properties' on the Printer properties window, select 'Print Test Page' (button at the bottom of the window.
Let me know what's the reseult.
Mar 11, 2007 | Canon MultiPASS C530 InkJet Printer
Brother MFC-465CN InkJet Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
