Question about Flotec TC2151 P2 Well Pump Pressure Switch
What preasure should it stop pumping - Flotec TC2151 P2 Well Pump Pressure Switch
    Problem Solver:
  • 4 Answers
It is factory preset to stop at 50psi but is adjustable. Do you have a pressure tank in line and close to the pressure switch to assist in pressure stabilization?
Posted on Nov 08, 2010
Loss oil preasure in my 351 L
Sure sounds like stopped up return passageways, common in old engines. Or a failing oil pump, not common. Are you sure about this low mileage? Pull a valve cover and check for sludge.
Nov 26, 2013 | Cars & Trucks
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
Stop Engine, Low Oil Pressure message comes across message center when vehicle stops at a red light or stop sign for 30 secs or more
If you rev the engine does it go away? What is probably happening is that you have damaged or worn engine bearings. These bearings are designed so that there is a gap(clearance) between the crankshft and the bearing. This gives a space for the oil to pass through. If the clearance is too big the oil will pass through too quickly and the oilpump will not be able to build up pressure, even though the volume of oil pumped is sufficient.
When the oil is cold it is thick and the sensor sees the pressure as normal. As the engine oil heats up it gets thinner and that causes the pressure to drop. Also the lower the RPM the lower the pressure. I would suggest you get the oil pressure tested at a service centre ASAP. Also have them test the sensor although sensor failure is rare. Low oil pressure will not just go away and causes more damage the more you drive increasing your repair bill considerably.
I'd say you are already in for a cranshaft regrind and oversize bearings. Perhaps (if you're lucky) only just an oil pump although this is unlikely as bearings tend to fail before an oil pump does. I'd replace both at the same time since the engine has to come out for both these repairs. The cost of having the engine out a 2nd time far outweighs the saving on spares when doing both the first time.
Aug 03, 2010 | 2002 GMC Envoy
Will a low oil level warning cause the engine to quit on a 1995 chevy caprice
It could, once the engine is running it then keeps the fuelpump running with the oil preasure switch and if the oil preasure drops it can stop the pump,but should start back up unless theres a bad fuelpump relay,
Jun 14, 2010 | 1995 Chevrolet Caprice Classic
Engine cranks well, starts momentarily when startin fluid is sprayed, then stops. driving when stuh down like turning off ignition
You have no fuel preasure check your fuel pump and relay,I bet your pump has went into retirement
Nov 30, 2009 | 1995 Dodge Ram 2500
I have a 1998 Jeep Cherokee with a 4.0L engine. The oil pressure gauge usually stays around 40 on the highway but when I come to a stop it drops down to 10. Is this normal or is my oil pump getting ready...
No this is normal. As an engine wears then oil preasure will be less this is not due to a weak oil pump but wear in crank shaft bearing's. When an engine is new and bearings are tight then oil preasure wont fall a lot from reved up to idle as the engine wear's oil escapes quicker from the crank shaft bearings. Reved up oil preasure increases idle it drops off. If the oil light stays out then their is enough preasure to lubricate the engine. In fact in an older engine high oil preasure is a worse complaint as this means the oil system is clogging. All is ok with your pump. If the oil preasure is moving up and down at constant rev.'s then the oil pump is faulty. Hope this put's your mind to rest.
Aug 11, 2009 | 1998 Jeep Cherokee
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Flotec TC2151 P2 Well Pump Pressure Switch Logo
154 people viewed this question
Top Flotec Plumbing Experts
john h
Vincent_G
Vincent_G
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
