Question about LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator
All power to the refrigerator has gone, all lights have gone out and compressor isnt working
    President:
  • 1,891 Answers
Ck the main power board as i think its failed .. ( in the back under a metal cover plate . ) board has fuses on it and will cause your problem when failed . the fuses are not a service part .. the p c control board is . mm hope this helps / feed back please ..
Posted on Nov 08, 2010
2000 sebring convertible 2.5l. compressor not getting power
check if this is a power wire or earthing wire, do a continuity test , one to chassis ,one to power , if get no continuity then the wire has a break in it somewhere
Jun 07, 2017 | Chevrolet Cars & Trucks
Hi, I have a whirlpool gold side by side fridge/freezer. I came home the other day and water all over the floor. I opened the freezer and it wasd hot. Opened the fridge, same thing. Light and fan work and...
Quick reference to your compressor says that it is a 120 V powered regular compressor.
It might be simple as starting device failure on compressor. Either capacitor or relay. Worst case compressor gone. Still not crazy expensive compared to a DC powered compressor.
Shut off the fridge (pull the plug) to prevent further damage to compressor and call a local service guy if you want to save the fridge.
Oct 25, 2017 | Kenmore 55603 Side by Side Refrigerator
Unit no longer gets cold,lights and fan still work, compressor isnt going on
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | KitchenAid KBLA22KLSS Bottom Freezer...
F refrigerator isnt getting cold
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!!
Apr 08, 2010 | Jenn-Air JCD2389G Side by Side...
My 12 year old Whirlpool 167cm Free Standing Fridge Freezer has stopped working. There is still power to it, since the light comes on in the upper fridge compartment? Has the compressor gone? Coventry...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 10, 2010 | Refrigerators
I have U-line Model #75RB-00 Refrigerator, the motor does not run and no cold air, light does work
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
Oct 01, 2009 | U-Line ?chelon 2175RB-00
Model dss25pfmdww quit cooling
We do need to check the PC board part number WR55X10656
Jul 24, 2009 | GE GSS25JEM Side by Side Refrigerator
Refrigerator and freezer won't get cold
Check the compressor for voltage and make sure that it is getting power. If it is getting power and not starting then the compressor is shot and the cost to replace is about 450 to 600 to replace. If that has voltage but you want to double check you can check the relay on the back of the unit and make sure that it has power going to it and from it. Then you know for sure that the compressor is gone
Feb 14, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Lights inside are on but no fan or compressor, is there a fuse?
No a refridgerator does not have a fuse, it could be that your thermosta has gone, the wires from the back of the fridge come through the back to the thermostat, the lights work on a different poer supply ie they are not connected to the thermostat, try take the power directly from your outlet to the compressor at the bottom of the fridge, the wires work as follows, you have 3 a earth a live and a neutral, the live goes up to the thermostat and light, but there are 2 lines, 1 for the light 1 for the thermostat, then the thermostat has a line which goes down to the compressor and 1 to the defroster, the line to the compressor then turns it on and off when the unit reaches the tempreture desired, so it is most likely a split in the wire or your thermostat has gone. however i would not suggest testing anything if you are not expirienced in working with electrical systems, however should you wish to connect the live wire straight to the compressor to see if it is the thermostat or a split in the wire, always remember to turn the power off and unplug the unit. good luck and i hope this helps
Dec 11, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor is trying to start
can be or the capacitor thats the one do the first push to te compressor to start it
Dec 27, 2007 | Kenmore 72073 Top Freezer Refrigerator
LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
193 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
