Question about Brother Office Equipment & Supplies
I have a brother photocopier DCP-8040/8045D Series. We have a error 7a come up on copier, It started when paper got jammed at ther back of machine and weas pulled out from the back, ever since then when you turn the machine it makes a loud clicking sound, then the error message sound comes on.
  • 1,218 Answers
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
    Problem Solver:
  • 6 Answers
Turn off the unit and remove the toner cartridge to visually inspect for more paper. Replace cartridge if necessary. Also the problem may be in the fuser. Good luck and God bless.
Posted on Jun 16, 2008
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
Error 50 of Brother printer DCP-130C
Details of this error code are.
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
Not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Aug 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
Machine error 7a on brother mfc8640d
Same problem with mine! You can replace cheaper than repair!!!!!
Apr 28, 2009 | Brother DCP-8040 Copier
Paper fed error
check the paper jam clear cover at the back site of printer:
When taking it out you can see the wave formed clear plastic which is on top of the cover.
try to stroke with your finger alongside. this can be the reason for the paper jamming.
Mar 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print
press menu then start mono then 4x arrow-up. machine will be in maintanance mode. what error code does the machine display?
to leave the maintanace mode simply unplug machine from power and reconnect again.
Nov 06, 2007 | Brother DCP-110C All-In-One InkJet Printer
265 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
