Fan runs all the time can't get heat or ac to turn on have to unplug heater at outlet to turn fan off
    Genius:
  • 1,015 Answers
Does this unit have a thermostat on it.If it does there may be a fan run position where the fan would run as long as power was on .See if there is seperate setting for heat and cooling and try them.Hope this helps.Thanks.
Posted on Nov 08, 2010
When you turn the A/C on does the elect. fan suppose to come on evenin cold weather and whitch temp. switch runs it?
Normally the ac fan (in front of the condenser) will run as soon as the ac is switched on. This condenser gets hot when the gas is being compressed and needs to have the heat removed for the system to work IT will switch on regardless of the ambient temperature as it is connected directly to the ac compressor clutch. IF you are referring to the heater fan inside then it will only work with the heater fan on or with both ac and heater on but will not always work with just the ac on.
Dec 24, 2013 | 1991 Oldsmobile Cutlass Ciera
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Jul 05, 2013 | Dometic 3313192.000 White Single Zone LCD...
I have two outside ac one for floor and other for upstairs and i button on heater auto and ac outside fan is running is that normal or not? and live on this new house for two years and cant find someone...
No the fan out side is for a condensing unit and compressor. The compressor should not run with the heat. I am almost positive that if this is not a heat pump that the compressor unit should not be running.
Dec 20, 2010 | Goodman GMS90703BXA Heater
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
My heater fan wont turn on in auto mode but will in manual
Well you have a good transformer and the fuse is not blown. So I would look for the most obvious thing which is the relay. Why the relay? Well most units do double duty as air conditioner and heater. AC and heat require different fan speeds. The relay shifts the fan from low to high for ac. The fan runs on low for heat. In rare instances it could be a bad wall thermostat but most times not. You know the fan is good because you can get it to come on manually.
Some Repair Photos
Dec 24, 2009 | Heating & Cooling
HEATER REPAIR
chances are it is your heater core , it don't have to leak just get stopped up . it has tiny vanes and the antifreeze has to run through them. I know the your heater hoses outside on the motor are different sizes but switch places with these two hoses connected with heater core it will change the flow direction and chances are unplug it.
God Bless Greg
Nov 24, 2008 | 1999 Cadillac DeVille
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Heater
Try spinning the knob real fast in either direction. Sounds stupid but it worked for me.
Sep 27, 2008 | 2005 Chevrolet Malibu
Car problems
In my country, most overheating issues on Volkswagen models are resolved by:
  • entirely removing the thermostat (not applicable in cold regions);
  • wiring the fan to switch on once the engine is running (with or without the A/C or heater being turned on);
  • replacing the radiator thermal switch for the fan to a lower temp.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | 2001 Volkswagen Jetta TDI
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
