Question about TalkSwitch TS-400 Phone
How to reset time and date on TS-400 talkswitch phone
We have a Talkswitch system at our office. My Talkswitch 480i now seems to has lost its brains. When I power it down now, it does not seem to talk to the switch to obtain its configuration. It always...
The problem would seem like the phone is not finding the TalkSwitch system, or the configuration file for the phone does not exist. There are usually only 3 things that can cause this issue to occur:
1. Verify that the IP address for the TFTP Server, this must be your current public IP address. This can be found in the phone's menu under Networking -> TFTP Server -> Primary TFTP Server
2. Ensure that port 69 is open in the firewall at the TalkSwitch's side. Run the TS firewall test to confirm that it passes.
3. Confirm that you have the correct MAC address entered in for the Extension in the TalkSwitch software
Jan 05, 2011 | TalkSwitch TS-480i
If someone is using a headset with a TS-200 multiline system, will incoming calls be picked up by the phone in headset mode first?
That should be a configurable setting. Speaker, Headset, Speaker then headset or Headset then Speaker.
Jun 25, 2010 | TalkSwitch TS-200 Phone
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
Nov 25, 2009 | TalkSwitch TS-9133i
How do I access my voice mail remotely? (talkswitch ts200)
Call into the system and when the attendant picks up dial **+(mailbox number or extension number)
Aug 03, 2009 | TalkSwitch TS-200 Phone
Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
Number of Rings Before Pick-up
Log into your Management software.
Go to each phone line.
At the very bottom of the call handling section you should see routing options. Change these setting to the desired number of rings.
Hope this helps you.
Oct 22, 2008 | TalkSwitch TS-480i
Somethings wrong!
Sorry to have to ask all these questions, but they are necessary to try to help figure out what is going on. I need to know what TalkSwitch system model you are using and what version of software it is running. A system serial number is required if I need to contact my distributor. If you could provide the current configuration file on the system, that may help as well.
I am an authorized TalkSwitch Partner and will try to assist you.
Sep 28, 2007 | TalkSwitch TS-400 Phone
TalkSwitch TS-400 Phone Logo
126 people viewed this question
Top TalkSwitch Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
